vista 64 = noesss
Discussion in 'Tech Support' started by keef247, 19 Feb 2008.
  1. keef247
    keef247 Minimodder
    11 Aug 2006
    so what do i do?
    i tried formatting partition xp was on and no go. tried making a new one in vista 64 installer but no go:angst:
    bloody 64bit. everything worked fine till then grrr.
    now i keep getting "windows is unable to find a system volume that meets its criteria for installation"
    is it because its 39.5gb and it requires 40gb?
    i'm going to try and resize my partition to say 45gb now to check...
    i'm lost here:S
    hardware is
    abit ip35
    hd3870 pcs
    2gb ballistix
    q6600
    wd 320 x2 sata's
    tagan 500w
    pioneer sata dvdrw...
  2. keef247
    keef247 Minimodder
    11 Aug 2006
    wierdddd... i had a fat32 linux partition of 30gb's setup and i deleted that a did "new" and now its installing:S yet ntfs wouldn't work even when creating a new partition.
    lol beats me but least its working...
  3. Delphium
    Delphium Eyefinity enabled
    18 Mar 2007
    Dint try creating a NTFS partion in an extended fat32 partiton by any chance?
    If you have deleted all partitons, then you should have no issues formating it to NTFS.
  4. keef247
    keef247 Minimodder
    11 Aug 2006
    yeah its fine now i tried again and am back on the previous one that wouldn't work.weird:S
  5. WhiskeyAlpha
    WhiskeyAlpha What's a Dremel?
    5 May 2006
    Glad to hear you got it sorted keef247 :thumb:
    But what is with this whole "blame Vista" attitude everyone seems to have adopted.
    Likely, it was nothing to do with vista, even less chance the fact it was the 64 bit version.
    If you had trouble installing Linux on a clean partition (which I have :)) you wouldn't "blame linux" because it's viewed as the elitists weapon of choice. You'd be left with the mentality that you must be doing something wrong yourself, as others have done the same with no such trouble.
    Along with vista's "dumbing down" seems to have come the wrath of anybody who encounters any type of problem with it (even when the problem is before it's installed!).
    I've been using Vista 64 for some time now and whilst it admittedly had teething problems, it's a fantastic OS for home use.
    Sorry for the rant and OT. I feel better now ;)
  6. keef247
    keef247 Minimodder
    11 Aug 2006
    nah it was purely a joke mate.cause i knew it wasn't 64 bit nor vista i knew something was just throwing a fit haha hence why when i rebooted it worked fine.lol.sorry for the misconception of my wording lol.
  7. AlexB
    AlexB Web Nerd and WC Addict
    22 Dec 2005
    Good rant. And I agree. I was also an early adpoter, and I'd never go back to XP.
    Vista is faultless as long as you're not a numpty.
  8. keef247
    keef247 Minimodder
    11 Aug 2006
