Windows vista aero glass problem
Discussion in 'Software' started by M4RTIN, 5 Nov 2006.
  1. M4RTIN
    M4RTIN What's a Dremel?
    11 Sep 2006
    how exactly do i go about getting glass to work on rc2. i've gone through what the help file says to do and its not on the themes list, only vista basic is.
    my graphics card is capable of running it and i've just updated to the newes forceware drivers.
    my spec is
    semrpon 3100
    512mb pc3200 ram
    geforce 6600 pci-e
    if it helps here are the performance scores too
    processor: 4.2
    memory: 2.9
    graphics: 4.0
    gaming graphics: 3.9
    hard disk: 5.3
    the ram is a bit on the low side, maybe i need a higher score to run glass? i cant find the info anywhere
  2. Bogomip
    Bogomip ... Yo Momma
    15 Jun 2002
    Whats interesting is my Radeon 9600 got a better gaming graphics score than you - and I was under the impression scores couln't go over 5.0 :S
    Sorry, that wasn't useful - just some thoughts and musings ;)
  3. Ramble
    Ramble Ginger Nut
    5 Dec 2005
    What are the specs on the card?
    EDIT: Maybe it uses the combined scores for working out if you need glass.
    In any case, there are registry hacks out there, a quick Googleing should find them.
  4. DougEdey
    5 Jul 2005
    Are you using a 128MB card?
  5. M4RTIN
    11 Sep 2006
    yeah its the 128mb DDR version..
    afaik a 128mb card is the required one for glass tho, it must be the ram thats the problem as its score is highlighted in grey for some reason too
  6. M4RTIN
    11 Sep 2006
    got the registry hack working now.. runs absolutely fine, and after more poking about it seems you need 1gb of system ram for glass to work and 64mb video memory, so i was alright on one
  7. <A88>
    <A88> Trust the Computer
    10 Jan 2004
    Glad there is a registry hack, as I'm getting a lappy with 1gb of shared memory and wouldn't bother putting Vista on if it resorted to the basic skin.
    <A88>
  8. Mother-Goose
    Mother-Goose 5 o'clock somewhere
    22 Jul 2004
    in RC1 you can run it with 512mb, in RC2 you cannot unless you create the hack.
    I think the scores are out of 10.
