Vista - barred from my own folders
Discussion in 'Tech Support' started by cpemma, 26 Jan 2008.
  1. cpemma
    cpemma Ecky thump
    27 Nov 2001
    Am I alone here in being unable to get into a number of "my" folders in Vista? "Location Unavailable" and "Access denied" comes up for C:\Users\Howard\Application Data, \Start Menu, \Sendto, \Templates and several more, including C:\Docs&Sets. I'm Administrator and sole User, 'Folder Options' has everything ticked to show everything.
    The forbidden folders have a Shortcut arrow but no properties giving a path to their location.
    This is a major annoyance as
    • I want to tidy up the mess that is the Vista programs menu with a hierarchical folder system; dead easy in 9x and XP. [I've solved that one - right-click on the 'Start' button and Explore.]
    • I want to add programs like Notepad and Paint Shop Pro to the 'Send to...' list; [Solved]
    • I want to be able to pick what Application Data I back up, etc.
    edit: Found some workrounds but Vista seems to make life much harder for the tinkerer. :grr:
  2. badders
    badders Neuken in de Keuken
    4 Dec 2007
    Try:
    C:\Users\Howard\AppData\Roaming\Microsoft\Windows\Start Menu\Programs
    C:\Users\Howard\AppData\Roaming\Microsoft\Windows\SendTo
    Or are these the ones you're referring to?
  3. cpemma
    cpemma Ecky thump
    27 Nov 2001
    It's all the crap shown with shortcut ( :rolleyes: ) arrows. I mean, what's the point of showing those folders when the real ones are elsewhere and the "shortcuts" don't take you there, forbidden to all, including the so-called "administrator". I'm finding Vista annoying. :grr: If I wanted pain I could have installed Linux.
  4. Firehed
    15 Feb 2004
    You shouldn't be getting errors like that unless you did something insane with the permissions. I know the Windows permission model sucks and is doomed to do so for the rest of eternity and then a few weeks, but I can't say that I've seen a shortcut fail to fire off because of that.
    I'm assuming you've checked the security settings for the folder(s) in question, have the right access, haven't revoked anything, etc., etc., right?
  5. badders
    4 Dec 2007
    I think that they're disallowed to users (any users) but not to the system, to allow compatibility with older programs that have the XP user model hard-coded.
  6. AlexB
    AlexB Web Nerd and WC Addict
    22 Dec 2005
    I get this every now and then, usually after installing a game demo.
    (from memory - will update when I get home)
    Right click folder > properties > security > advanced(?) > owner > set new owner > select admin > make sure its recursive > ok > ok - and it should be OK
  7. cpemma
    cpemma Ecky thump
    27 Nov 2001
    These are folders that are invisible by default; mortals are not supposed to be looking at them. It just seems to be the totally paranoid approach to security that is Vista. I added a couple of common switches to Explorer and it went berserk and made me confirm Explorer was "safe". Use msconfig to uncheck the nuisance Startup items that always get added with a new install (Acrobat, Quicktime, etc) and next boot you get a "Go to Guantanamo Bay, do not pass Go" card. :eeek:
    On the other hand, tabbed Exploring is nice - very foxy. ;)
