Windows vista bluescreening...
Discussion in 'Software' started by Onyx, 2 Mar 2007.
  1. Onyx
    Onyx What's a Dremel?
    13 Jun 2006
    hello. i am not exactly sure whats up with my laptop. i have an alienware m5750 with vista home premium upgrade (clean install). Vista keeps blue screening randomly. It says something like "a process or thread has causes the machine to halt" or something along those lines. and then makes the usual memory dumps. this is about as much information that i have atm. so that being said do you think its:
    A. virus
    B. Windows Vista being typically windows
    C. Other?
    at this rate ima consider moving to Linux fulltime
  2. Ramble
    Ramble Ginger Nut
    5 Dec 2005
    I've been using Vista for a long time and then only time it ever BSODs is when:
    a) Shite drivers
    b) I've overclocked it too far
    I'd check the drivers if you can (go into safe mode).
  3. Onyx
    13 Jun 2006
    hmmm im not sure if this is relevant but do you think Daemon tools could be a culprit?
  4. Ramble
    Ramble Ginger Nut
    5 Dec 2005
    Easily possible, since Daemon tools installs it's own driver.
    I've not had any trouble with it, but it can't do any damage to remove it and try.
  5. Brooxy
    Brooxy Loser of the Game
    20 Apr 2006
    I remember in the Vista beta versions it used to throw an eppy at daemon tools....might be that...
  6. Onyx
    13 Jun 2006
    hmmm i will try disabling it and see what happens
  7. DougEdey
    5 Jul 2005
    I'm running Daemon tools on Vista Business. Works fine.
    I was get loads of BSODs because I had overclocked. XP was fine with it, but Vista wasn't
  8. vags
    vags What's a Dremel?
    5 Mar 2007
    Look and the bluetooth drivers.
