Notebooks Vista keeps freezing
Discussion in 'Hardware' started by ladyangel, 2 Feb 2008.
  1. ladyangel
    ladyangel What's a Dremel?
    2 Feb 2008
    Hi
    Don't know if im posting this in the right place!!
    i have a HP Pavilion Laptop dv9341eu, running windows vista home premium and i recently purchased a "PCMCIA cardbus Host into Express card/34 slot converter adapter" .
    but everytime i push it into the slot, vista locks up and i can't do anything, when i pull it out everything runs as normal again.
    any ideas?
    thanks
  2. Fredrics
    Fredrics Hmm...
    31 Dec 2007
    Go to the cards manufacturers website and see if the card supports vista. If so make sure you have the latest vista drivers. If the card doesnt support vista i hope you can get a refund!
  3. GoodBytes
    20 Jan 2007
    this sounds like your PCMCIA card doesn't like Vista. Make sure you purchase Vista ready products, or well anything newly manufactured.
    Also I think you should contact the company of your card for perhaps instructions for a firmware update or replacement.
  4. ladyangel
    2 Feb 2008
    thanks for the advice :)
    I'm sure the one i ordered said it was compatible with vista. i will contact the manufacturers like u said.
    thanks again
  5. evileclipse
    evileclipse Toxic Waste!
    29 Mar 2006
    bin it if it has vista put xp on the laptop and it will work
  6. ladyangel
    2 Feb 2008
    yes, thankyou jay i am aware of your opinions about my laptop and vista:p
