Vista Licences???
Discussion in 'Hardware' started by davie107, 14 Feb 2008.
  1. davie107
    davie107 Linux or Windows???
    18 Dec 2007
    I have just bought vista home premium oem and have installled it on my pc. I am in the process of building another pc for my mum and i was wondering if i could instead of buying another copy of vista home premium just buy the licence/sticker you put on the side of your case. Is this possible or will i have to buy another copy of vista?
  2. badders
    badders Neuken in de Keuken
    4 Dec 2007
    When you buy a copy of Vista, what you're paying for is the license anyway, so both options are the same.
  3. crazybob
    crazybob Voice of Reason
    21 Oct 2004
    Badders is correct, but I don't believe you can buy just the sticker, and even if you can it'll cost exactly the same as the disk.
  4. mushky
    mushky gimme snails
    24 Mar 2003
    Is this about the difference between OEM and retail?
  5. badders
    4 Dec 2007
    Not really, he's asking if buying just a license is cheaper than buying license + Disk.
    It's not.
