Windows Vista Licensing Question
Discussion in 'Software' started by vaderag, 4 Apr 2008.
  1. vaderag
    vaderag I know what a Dremel is...
    19 Jul 2007
    I have a full copy of Vista Ultimate, that only has a 32 bit DVD. I am going to have to re-install at some point in the future, because i cant install SP1 for some annoying reason, but was wondering whether my licence will cover the 64bit version instead (if i got hold of the disc)?
  2. kenco_uk
    28 Nov 2003
    Yes, apparently. A 32-bit key will install the same 64-bit version. As long as you get the correct media, you're good to go.
  3. vaderag
    19 Jul 2007
    Ah, excellent. Is it legal to get hold of the disc via 'questionable' methods in this situation?
  4. oasked
    oasked Stuck in (better) mud
    24 Aug 2005
    That's up to you, it should work though. (I would).
    Might be hard finding the right version of the disc though (OEM vs. Retail vs. Dell etc)
  5. vaderag
    19 Jul 2007
    Would it be the Microsoft Windows Vista Ultimate x64 Retail Edition DVD that i need?
  6. E.E.L. Ambiense
    E.E.L. Ambiense Acrylic Heretic
    26 Jul 2007
    I thought the retail version of Ultimate was the only one to ship with both x86 and x64? Of course, I have no brain, so take that under advisement. ;)
    But yes, you can get it directly from Microsoft for a small fee plus shipping here.
  7. oasked
    24 Aug 2005
    What version is your current 32-bit license? Retail? OEM? Did it come with your computer?
  8. Smilodon
    Smilodon The Antagonist
    25 Mar 2003
    I may be wrong here, but I think the media is the same (as in just two version, 64, and 32 bit) on all versions. it's just the key you enter that determines what version will be installed. I know this is true for volume licenses, but I'm unsure about retail/oem.
  9. Ramble
    Ramble Ginger Nut
    5 Dec 2005
    The key works on both versions. You can get ahold of the media whatever way you wish, provided the key is legal than Microsoft don't care.
  10. vaderag
    19 Jul 2007
    I'm not entirely sure... i got it from a Microsoft Focus Group i did, so it says the following on the back
    It's def full vista ultimate tho...
  11. jkeyser14
    jkeyser14 What's a Dremel?
    26 Mar 2006
    If you call up Microsoft's media replacement department, give them your license key and ask for the 64-bit version, they will ship it with the same license code for only $10. Can't go wrong as it's completely legit.
  12. vaderag
    19 Jul 2007
    Do you happen to know where I can find that number for the UK?
  13. jkeyser14
    26 Mar 2006
  14. Hazardous
    Hazardous What's a Dremel?
    21 Jan 2004
    You can order the alternative DVD (64bit in your case) here ;)
    IIRC... mine (for Home Premium) cost £7.68?
    And yes... you can use the same serial for both/either version :thumb:
  15. vaderag
    19 Jul 2007
    Great. That website wont let me order a 64bit version as it says it should have been in the box. However, my disc only includes the 32bit, and it's the only disc i have...
  16. Smilodon
    25 Mar 2003
    What kind of cover did it come in? Retail should be in this large cover with two rounded corners, while the OEM comes in a (transparent) DVD cover.
    The latter only support one version.
  17. vaderag
    19 Jul 2007
    It's neither - it's a bright orange dvd case that says Ready for A New Day on the front! As i say - it's a promo copy that they gave me at a focus group i did for MS.
  18. jkeyser14
    26 Mar 2006
    Just call them up, it's your best bet.
  19. naokaji
    naokaji whatever
    8 Dec 2006
    jus d/l the 64 bit version anywhere and use your own key, since you have a legal key they wont care.
  20. kenco_uk
    28 Nov 2003
    It's what I've just done today, got hold of an x64 iso and installed using a 32-bit key. Chuffed to bits it works!
