Windows Vista "my computer" OEM logo
Discussion in 'Software' started by Bluephoenix, 26 Apr 2007.
  1. Bluephoenix
    Bluephoenix Spoon? What spoon?
    3 Dec 2006
    I do system builds for others around campus here at uni, and have been wondering how to edit the OEM logo information.
    In XP its a registry key, but I've had no luck so far figuring it out with vista.
    anyone know what the key is for vista (or another way of changing it?)
  2. Ramble
    Ramble Ginger Nut
    5 Dec 2005
    Yes, there is a way to change it, I think it's done by an inf file somewhere. I remember reading a thread on it over at Neowin, have a look in their Vista customisation forums.
  3. Bluephoenix
    3 Dec 2006
    no joy.
    I ask mostly because I take some pride in the systems I build, and wish to show who took the time and effort to build them.
  4. Hazardous
    Hazardous What's a Dremel?
    21 Jan 2004
    I don't know if these will work in Vista... but there's one way to find out :D
    It doesn't say it's Vista compatible specifically, but it's gotta be worth trying this small (468kb) / FREE OEM Information Changer program first?
    Alternatively... here's a couple of more convoluted methods which should work for Vista:
    Changing the OEM info in the System Properties window
    How can I change or add OEM logo and information on my computer?
    [edit] Again... I don;t know if it works under Vista... but I've just remembered another program which you could try!
    WinCust [also] makes it easy to change the logo, registered owner and organization ;) [/edit]
  5. Bluephoenix
    3 Dec 2006
    Vista is slightly different, I found the OEMinfo file, but it's some unreadable filetype.
    I'll continue digging and see what I can find.
    (I knew the XP process, it didn't work on vista so I asked here..)
  6. Hack'n'Slash
    Hack'n'Slash Minimodder
    20 Dec 2001
    Is this any help?
  7. Bluephoenix
    3 Dec 2006
    Perfect.
    Cheers :clap:
