Windows vista problems
Discussion in 'Software' started by Archtronics, 30 Jun 2006.
  1. Archtronics
    Archtronics Minimodder
    27 Jun 2006
    i recently got vista on a disk but when i click the setup shortcut it says i dont have appropriate permision to access the item
  2. Arthur2Sheds
    Arthur2Sheds Jackson
    19 May 2003
    Do you have Admin rights on the box?
  3. Archtronics
    27 Jun 2006
    reply
    yes i think i do also if i click another setup link it says there is isscript.msi older version ive installed the updates but nothing new happens
  4. Arthur2Sheds
    19 May 2003
    Are you currently running XP Home or XP Professional? Once we have figured this out, then we can find out whether or not you have Admin rights. It still sounds like a permissions problem to me.
  5. Archtronics
    27 Jun 2006
    im running xp home i also explored the disk and found another link were it said i had a isscript problem the disk is a copy of an oringional i got off my friend
  6. fathom17
    fathom17 What's a Dremel?
    20 Sep 2005
    It would be recommened to just bootup the dvd. It would make it a lot simpler.
  7. Archtronics
    27 Jun 2006
    when i try that it says insert proper boot device
  8. Drastik
    Drastik What's a Dremel?
    10 Jan 2002
    maybe the burn didnt go right
  9. Archtronics
    27 Jun 2006
    i got the original disk that worked on my friends pc but it still wont work on mine
