News Vista SP1 timeline revealed
Discussion in 'Article Discussion' started by Tim S, 30 Aug 2007.
  1. Tim S
    Tim S OG
    8 Nov 2001
  2. DarkLord7854
    DarkLord7854 What's a Dremel?
    22 Jun 2005
    I find Admin to be kinda screwy with Vista, like when I try to edit files and it says I don't have admin rights to it.. Yea.. >.>
  3. Awoken
    Awoken Gazing at the stars
    3 Mar 2004
    I'm impressed with Vista on my gf's laptop, it runs smoothly and all the programs she usually uses are compatible. I might make the jump after sp1 depending on how it gets on with games (I'll probably go dual boot for XP and older games).
  4. Mister_Tad
    27 Dec 2002
    Hopefully I'm in that 10,000 getting SP1 in a couple weeks, will probably just go for it then, after all, how beta can it be /touches wood :worried:
  5. LeMaltor
    LeMaltor >^_^
    3 Oct 2003
    I lol'ed :lol:
  6. wafflesomd
    wafflesomd What's a Dremel?
    22 Oct 2005
    Which part says it won't hog up half of your ram?
  7. LeMaltor
    LeMaltor >^_^
    3 Oct 2003
    Google Vista ram management and educate yourself :thumb:
  8. Buzzons
    Buzzons Minimodder
    21 Jul 2005
    Well said LeMaltor
    Slagging vista off when equipped with he facts is ok, when you just blindly abuse it.. that is just wrong
  9. Mister_Tad
    27 Dec 2002
    It is quite amusing when people buy 2-4GB of ram and then complain when it actually gets used.
  10. Ramble
    Ramble Ginger Nut
    5 Dec 2005
    Actually Vista 'hogs' up near to 100% of your RAM, that is if you count the superfetch cache.
    For actual background processes it hogs up around 30-50%. Notice I used %, because this is virtually true no matter what amount of RAm you have. 4GB, 50%. 2GB, 50%. 1GB, 50%.
    Also, it drops that usage faster than a green snake up a sugarcane when an app actually needs it.
  11. wyx087
    wyx087 Multimodder
    15 Aug 2007
    hah, yeah. i love Vista's RAM managment. go into a game, game uses 700MB out of my 1GB, exit the game, Vista uses 500MB. minimum wasted!
    hope SP1 fix the "start menu search 'word' can't launch Word 2007 issue".
  12. Sam0r
    Sam0r It's been a while
    24 Jun 2005
    Works fine for me, unless you're on about something other than pressing winkey > typing 'word' then hitting enter?
  13. wyx087
    wyx087 Multimodder
    15 Aug 2007
    yeah, i've got Word 2007 installed, hit Start key, type Word, and press Enter when Microsoft Office Word 2007 is selected does nothing what so ever.
  14. Sam0r
    24 Jun 2005
    Weird, try doing it fast. Like w-o-r-d-enter instead of waiting for anything to come up.
  15. GoodBytes
    20 Jan 2007
    Would be nice if SP1 makes Vista boot a bit faster.It's not an issue for me (currently) as I leave my comp turn on. But I'm thinking of getting a laptop, and I will shut-down here and there, and I don't want to drain my battery because it takes forever to load.
  16. Brooxy
    Brooxy Loser of the Game
    20 Apr 2006
    I just leave mine in standby. When it's on, the battery lasts only for about 1.5 - 2 hours dependant on usage, but in standby, I can quite happily go to work, come home and nearly have a full battery. Hopefully, SP1 will give a better shutdown time, as it takes a fair while on my laptop
  17. paul2345
    paul2345 What's a Dremel?
    17 Aug 2007
    Vista occupy too much ram for me , i hope this can be improved.but it really looks cool and shine.:worried::worried:
  18. wyx087
    wyx087 Multimodder
    15 Aug 2007
    doesn't work.
    it has to be a shortcut. if you open word's property, it's not a shortcut, it's just says "target: Microsoft Office Professional 2007"
  19. Nikumba
    Nikumba Minimodder
    29 Aug 2001
    How much does it occupy? By design Vista is made to use your ram to give you a better user experience rather than just doing nothing with it.
    Kimbie
  20. ComputerKing
    8 Sep 2006
    Vista is amazing without any SP1 But Who knows ;)
    Thanks for this information. CK.
Tags: Add Tags
