News Vista updates improve compatibility, performance
Discussion in 'Article Discussion' started by Tim S, 9 Aug 2007.
  1. perplekks45
    perplekks45 LIKE AN ANIMAL!
    9 May 2004
    Sorry, I'm an idiot... studying computer sciences....
    I KNOW what RAM is made for! But jusk to piss you off: Why should I store data in my RAM that I might eventually maybe need later? I agree that's something to argue about but just my 2 pence added here.
  2. TheVoice
    TheVoice What's a Dremel?
    14 May 2007
    If the RAM is sitting there doing nothing, why not?
  3. SNIPERMikeUK
    SNIPERMikeUK What's a Dremel?
    21 Feb 2006
    Just installed the 2 updates on x64
    The larger of the two updates gave me a blue screen of death crash, when it was shutting downafter install, but seems to have been installed fine. On the whole vista home premium x64 has done me proud, it is mainly problems with itunes ect I have, it is a lot quicker than my system was with xp running on it.
  4. Kipman725
    Kipman725 When did I get a custom title!?!
    1 Nov 2004
    more cpu time used when a program starts or a program starts demanding more ram as the operating system has to decide where to get the ram from etc. instead of just giving the program a load of address which it knows is free.
    As for linux... the ram usage is less than vista but more than xp on most of my boxes. It seems to keep a percentage free as the more ram you add the more it uses.
  5. quack
    quack Minimodder
    6 Mar 2002
    I agree, UAC is annoying in its default mode, but if you use TweakUAC and switch to the Quiet mode, Vista is a lot more user friendly. Turning UAC off completely can actually cause you problems since doing so disables write access to the Temp folder.
  6. Nedsbeds
    Nedsbeds Badger, Slime, Weasel!!
    16 May 2002
    Because ram is a lot faster than your disk...
    And there isn't anything to argue about. It simply makes a lot of sense.
  7. smoothie
    smoothie What's a Dremel?
    28 Jul 2007
    I'm having a lot of problems with driver compatibiliy with Vista x64. Many more than I feared I'd have.
    Is it possible to run Vista x86 on 64-bit processors?
    How would I go about swapping my OS to Vista 32-bit Edition?
  8. DougEdey
    5 Jul 2005
    Vista 32bit will work fine on a 64 bit processor. Not sure if you can swap though.
  9. Da Dego
    Da Dego Brett Thomas
    17 Aug 2004
    It works fine :) But requires a full reinstall.
    I use the x64 and it works great. Lots of things SAY they don't have drivers, but if you just right-click in device manager and set it to "update driver" it will miraculously find one. I had these problems with my wireless card, for instance.
  10. iwog
    iwog Linux cursed
    14 Jun 2007
    Question, how do you magically update drivers if the device you're trying to update is your only connection to the interwebs.
  11. Ramble
    Ramble Ginger Nut
    5 Dec 2005
    Get another network card?
  12. capnPedro
    11 Apr 2007
    Cat5e cable. Saviour of the universe.
    Assuming that your motherboard's onboard NIC is recognized. Which Vista does a very good job of doing, actually.
  13. Da Dego
    17 Aug 2004
    I suppose it depends which interweb you want to connect to. The toobs are full on many of them. But if you get one that's not, you can access it by your onboard LAN. I (very honestly) can't think of a board that doesn't have that feature that would even RUN vista.
    I may be an odd one, but I assemble my computers and get them all updated and patched up near two things - a working second computer, and a wired net router. THEN I take them where they'll spend their working lives. But then again, I may just be jaded from too many of those "everything you need is right in the box..." experiences.
  14. Woodstock
    Woodstock So Say We All
    10 Sep 2006
    hmmm ok it would be ignorance to vista then, was never really that interested in anything in it other than DX10, so when a game is launched vista removes stuff from the ram to fit the game?
    how does vista compare to xp then in games (fps wise) and benchmarks like super pi
  15. Ramble
    Ramble Ginger Nut
    5 Dec 2005
    The cached stuff in RAM is effectively free RAM, that's how the programs would see it and that's how you should see it since Vista will free up the cache instantly if a program needs it.
    In terms of FPS Vista is close, within 10fps of XP. But shoddy drivers so far have tainted the view.
    Superpi is identical for me.
    Vista actually has a new memory manager, so it's not just resource hungry, it's managing that memory in a totally different (and better) way.
  16. perplekks45
    9 May 2004
    So freeing up the RAM then load data is basically faster than just load data I guess? Sorry but thats utter crap. There ARE scenarios where this solution is definitly more useful than just keeping RAM load as small as possible and maybe even Windows IS such a scenario with a whole lot of data being used over and over again but as far as I understood the whole cache/RAM/storage thing each access costs time and READ, (ERASE), WRITE is slower than just READ, WRITE. As I said, if the benefits from keeping data in the RAM are big enough then it's making perfect sense as some ERASE calls now and then don't have that much impact on a system's performance then. But if there is a lot of different data permanently changing that needs to be erased and re-written into RAM then I'd say just keeping the load small should be the better solution.
    Sorry for being annoying, maybe not my day. ;)
    // edit: @ Ramble: Just a quick question: Is Vista still destributing RAM to other devices such as GFX cards? My 8800GTS/640 had 8xx or more MB of memory to address under Vista. Just wondering.
  17. Ramble
    Ramble Ginger Nut
    5 Dec 2005
    It takes a couple of nanoseconds to erase memory. I can't image even a German's reaction times being that fast.
  18. Bungle
    Bungle Rainbow Warrior
    7 Jul 2007
    Had Vista since April and so far the OS has been faultless. Had major stability problems running older games like quake 3 , wolfenstein ET so have bitten the bullet and done like a few others and installed a dual boot with XP. Have to say, Vista has been the best OS i've used so far from initial release. The score system for your hardware is a good idea for the average user so that you can gauge how the software will perform on it. The aero browser is great when looking through all those windows. Takes a while to learn your way around but overal Vista is very polished IMHO.
  19. Woodstock
    10 Sep 2006
    hmmmm thats interesting then lol, so how much ram does vista use if you get rid of the caching
  20. perplekks45
    9 May 2004
    That would lead us to "No matter what both solutions are almost equal performance-wise..." right? ;)
Tags: Add Tags
