Windows Vista voes(<sp?!)hard drive chatter when scrolling.
Discussion in 'Software' started by bixie_62, 14 Jun 2006.
  1. bixie_62
    bixie_62 Minimodder
    17 Jun 2004
    hey all
    have been running vista x64 for a few days now, and ive noticed, that its accessing the hard drive A LOT
    its using a gig of pagefile on average, but if im doing something like scrolling down a web page, i hear the hard drive chatter.
    whats the deal with this?!anyone else had this? how to remedy?
    is there any way i can get the os to go to RAM before hitting the pagefile, i.e. lowering the threshold at which it overspills to page file as it says ive got something crazy like half a gig of physical memory free!
    am gna pop in another half gig in a sec and will post back!
    ta
  2. Callum
    Callum What's a Dremel?
    4 Apr 2006
    Disable the pagefile? If you have half a gig of RAM free, and are adding another half a gig, you probably have enough RAM to run just fine without Virtual Memory...
  3. Drastik
    Drastik What's a Dremel?
    10 Jan 2002
    vista was using 850+mb ram just idling memory hog
  4. bixie_62
    bixie_62 Minimodder
    17 Jun 2004
    i've disabled the page file, and re-booted. but in task manager, it STILL tells me its using 1.33gb of page file! WTF!
    i've even upped the ram to 2gb now. it says theres 900mb free. this is really a bitc*!
  5. Callum
    4 Apr 2006
    Well, I haven't tried Vista at all, but I know on XP on this computer, I thought I had disabled the page file, but when I loaded it again, I hadn't. In XP, there is a "Set" button, that I hadn't pressed, I had clicked "OK" at the bottom of the window, and assumed it would work. Now obviously, Vista may have a very different settings box... But check anyway?
