Graphics VIVO software
Discussion in 'Hardware' started by wafflesomd, 14 Jan 2006.
  1. wafflesomd
    wafflesomd What's a Dremel?
    22 Oct 2005
    i wanted to hook up various things to my 7800gt, via vivo, but is there some sort of software i need to view it.
  2. hitman012
    hitman012 Minimodder
    6 May 2005
    For video in, you'll need to install the NVIDIA WDM capture drivers. They should be available on the driver CD that came with your card or NVIDIA's website.
  3. wafflesomd
    22 Oct 2005
    ok, after i have taht installed, whats next
  4. phuzz
    phuzz This is a title
    28 May 2004
    If you just want to watch something (eg ps2) then I'd recomend ATV2000, I managed to play on the PS2 using it without any noticible lag, and it's free :)
    For recording stuff, er, dunno, but window's moviemaker will work with the WDM drivers should you be feeling too cheap to look for anything better...
    (edit, btw, make sure you do get the up to date drivers from nVidia, I had big problems with them on my 6600GT before...)
  5. mrbojangles
    mrbojangles What's a Dremel?
    17 Jan 2006
    i would also like to use the vivo on my card, which cable should i use of the mass assortment that came with my card?
  6. phuzz
    28 May 2004
    Dunno, rtfm? On most cards it's the cable that plugs into the connector that's not the DVI or VGA (D-Sub) plug...
