Apple vnc help
Discussion in 'Software' started by x-rae, 16 Sep 2005.
  1. x-rae
    x-rae What's a Dremel?
    17 Nov 2003
    ok my mac is slowly but surely pushing my pc's usage down more everyday but i have yet to beable to completely let go. i hate having to reconnect dvi cables to my pc to do simple things like move a photoshop doc to share dir or turn off a program so could you guys suggest a good vnc program that doesn't require a b.a. in computer science to setup. thx
  2. solar
    solar What's a Dremel?
    6 Mar 2004
  3. Hamish
    Hamish What's a Dremel?
    25 Nov 2002
    if they're both running Win XP just use Remote Desktop under Programs -> accessories -> communications
    and enable it on the headless machine, my computer properties -> remote -> Allow users to connect remotely to this computer
    edit: synergy wont work unless you have a monitor for the headless machine already and seeing as he specifically mentioned swapping dvi cables i guess he doesnt :p
  4. Shadow_101
    Shadow_101 Mudkips.
    12 Feb 2004
    Ones a Mac, so I think RMs out the question. why don’t you try Real VNC, its dam simple to set up and should be fine for what you want to do. linky
    You could also enable the java viewer to VNC in from a browser incase you can’t find VNC client for the Mac
  5. Lorquis
    Lorquis lorquisSpamCount++;
    8 Sep 2002
    A B.A. is a batchelor of arts degree....
    Computer science is a science degree... thus it's a BSC in computer science...
    [/pedant]
  6. ArtificialHero
    ArtificialHero We were just punking him sir!
    25 May 2004
    Well if we're being pedantic it's not a BSC it's a BSc. /uberpedant
    AH
  7. Hamish
    25 Nov 2002
  8. burnoutuk
    burnoutuk What's a Dremel?
    18 Feb 2003
    As Shadow_101 said install Real VNC on your PC then use Chicken of the VNC on your Mac. Works quite well.
  9. x-rae
    17 Nov 2003
    thanks guys the real + cot vnc works great
