Other VNC Software
Discussion in 'Software' started by Blazza181, 26 Aug 2011.
  1. Blazza181
    Blazza181 SVM PLACENTA CASEI
    19 Apr 2011
    Can anyone recommend any free Virtual Network Control software, used for controlling a Ubuntu desktop from a Windows 7 Desktop?
    I have looked at RealVNC, but the fact it doesn't support Windows 7 does slightly worry me.
  2. Flibblebot
    Flibblebot Smile with me
    19 Apr 2005
    I use TightVNC without any problems.
  3. NuTech
    NuTech Minimodder
    18 Mar 2002
    I use RealVNC between computers running Windows 7 (64bit), Windows XP and OSX almost every day. Where did you hear it was unsupported?
    The only minor issue I can think of is while connected to a Windows 7 machine, RealVNC turns off Aero desktop on the remote computer until you disconnect.
  4. OCJunkie
    OCJunkie OC your Dremel too
    19 Apr 2011
    TightVNC is the one I use as well no problems, but I'm pretty pretty sure RealVNC works with 7...
