Other Voice commanding/voice recognition software
Discussion in 'Software' started by [KNIGHT], 4 Feb 2011.
  1. [KNIGHT]
    [KNIGHT] What's a Dremel?
    8 Dec 2009
    I want a voice recognition software for my computer so that i can command it with voice. Also i want to be able to convert my voice into words in text editors instead of typing.
    And it would be better if it allows me to add various commands to its existing list of voice commands.
    So what is the best software that is available for this task? Im running win 7 64 bit
  2. Agosen
    Agosen What's a Dremel?
    31 Jan 2011
  3. DMU_Matt
    DMU_Matt mmmm cheesy
    23 Oct 2009
    Windows 7 does also have its own (or at least easily available free from M$) Voice command and voice-to-text software. I remember using it before on my Windows 7 home PC. (can't remember exactly where I got it from and can't check 'cos at work....but there is one)
    Edit: See below VVVVVVVVVVVV
  4. RichCreedy
    RichCreedy Hey What Who
    24 Apr 2009
    does windows 7 built in voice recognition not work for you?
    just type voice in the search box on the start button
