Electronics Voltage supplied to PC LED Connection
Discussion in 'Modding' started by Moyo2k, 2 Jan 2010.
  1. Moyo2k
    Moyo2k AMD Fanboy
    11 May 2009
    I'd assume the power provided is 12V right and that to get the correct voltage for your LEDs you need to use a resistor? Also, does anyone know where I could buy the wires and connector for Power Sw/Power LED/HDD LED/ResetSw?
  2. capnPedro
    11 Apr 2007
    Nope, it's a little more complicated than that. Suffice to say, if you're using a standard LED (i.e. not some Luxeon Star style affair!) you don't need to worry about voltage or a current limiting resistor, just orientate the polarity correctly and you're good to go.
  3. Moyo2k
    Moyo2k AMD Fanboy
    11 May 2009
    So any old LED will do, will it alter the voltage sent or what?
  4. capnPedro
    11 Apr 2007
    Yeah, that's exactly what happens - coltage and current is regulated by teh motherboard, so manufacturers don't have to use any "standard" LED on their cases or worry about current limiting for different colours etc.
