Modding Volume Control in PC Drive Bay
Discussion in 'Modding' started by kiltman, 3 Jan 2003.
  1. kiltman
    kiltman Victory is Mine!!
    18 Jul 2002
    Arite there folks,
    i was wondering if it is possible to attach a volume control to your pc case in either your 5 1/4 or 3 1/2 drive bays, it would look something simular to what you have in your stereo to change the volume of the sound,
    hope you can help
    cheers kiltman
  2. loply
    loply What's a Dremel?
    26 Dec 2002
    Splice the coax cable to your speakers and put a rheostat on it? I suspect this would work, but its probably not the best way to do it :)
    Isnt there an article for this on the Bit Tech website?
  3. cderalow
    cderalow bondage master!
    23 Jan 2002
    if you have a soundblaster live card other than the values, there's a way to have some sort of volume control using slide switches if i'm not mistaken.... look in the articles section of bit-tech for the article... probably towards the very bottom of the listings...
