Motherboards Volume too low from rear panel, OK from the front?
Discussion in 'Hardware' started by Somer_Himpson, 2 Apr 2012.
  1. Somer_Himpson
    Somer_Himpson What's a Dremel?
    22 Jan 2010
    Afternoon all.
    I have just completed the buil din my sig and am having an issue with the volume.
    I have maxed out all available volume controls wherever possible and the sound (When my Corsair headphones are plugged into the mobo panel) is very quiet.
    When I plug into the front audio connectors on the case, volume is just fine.
    Any ideas?
    Volume full blast in X Fi control panel, the sound driver in Windows etc etc, all sound settings fiddled with no no avail.
  2. MSHunter
    MSHunter Minimodder
    24 Apr 2009
    sounds like ur on the line out and not the headphone out. Have a look you should be in the light green socket. Otherwise, drivers, drivers, drivers and not the crap on disk the ones direct from the Asus webpage nice and uptodate. Worst case you got a lose connection.
  3. Somer_Himpson
    22 Jan 2010
    Is in the correct socket, is plugged in all the way and has the latest drivers from the website.
