I have one of these pussies in my old system. I have just bent a PCI metal thingy and stuck a 60mm fan on it, its right next to the cards HS. what do you think would be a good clock for this, 143mhz atm. im using V3Tweaks to OC it. is there anyway to get a temp reading? .icecube
buy one, get some artic silver and some epoxy and stick it as close as possible to the core, and watch ur temps go up or down.... no point in really overclocking that unless you wanna have some fun burnin hardware....
i completly modded my V3 with a blob on the core side with thermal take ramsinks as well as a older pentuim 1 processor fan on the rear of the card, check it out at www.geocities.com/dukebox_1st2000/v3.HTML but i can still only get it to 180mhz without encountering the whole screen bluring to the right, any tips on getting it any further?cheers tom
