Build Advice VST hardware: mATX Motherboard, Onboard graphics, RAM and CPU
Discussion in 'Hardware' started by Sheepdisease, 7 May 2020.
  1. Sheepdisease
    Sheepdisease What's a Dremel?
    2 Dec 2009
    Hello, I've got a problem as the motherboard I was going to use doesn't boot despite trying many different fixes. My only conclusion is that it's a faulty onboard graphics chip.
    My plan was to use the following hardware to run a VST for eDrums with Superior Drummer 3:
    Asus M3A78-CM Motherboard with a
    Phenom II X6 1090T CPU,
    4X2GB 8GB DDR2 PC2-8500U 1066MHz 240Pin DIMM RAM with a Samsung 860 EVO 1TB SATA 2.5" Internal SSD
    I'm faced with a dilemma now as I would like multiple USB 3 ports and need to decide whether I get an identical motherboard, upgrade the motherboard to the best spec that the CPU will fit in (potentially having to get more RAM that is compatible) or upgrade everything (in which case I don't know what to go for). Whichever way we go, I need onboard graphics and a PCI slot.
    I don't want to spend loads/more than absolutely necessary. I thought having a six core CPU would be good but have read Intel can do better with less cores and there are less latency/buffer problems with Intel CPUs.
    Can anyone please share their thoughts?
  2. Vault-Tec
    30 Aug 2015
    Have you tried a discreet GPU in the mobo?
  3. Sheepdisease
    2 Dec 2009
    Thanks for your reply. I can't get one to fit in the case I am using.
  4. adidan
    25 Mar 2009
    That's got me curious, what's the case?
  5. Sheepdisease
    2 Dec 2009
    CiT S012B Slim Micro ATX/ITX Case for 300W Power Supply Unit with Built In Card Reader - Black
