Motors VW Polo
Discussion in 'General' started by ch424, 23 Dec 2005.
  1. ch424
    ch424 Design Warrior
    26 May 2004
    Hi people,
    My friend has managed to get hold of a two-month-old written-off Polo, and he'd like to make a beast of a go-cart/buggy thing. :naughty: However, I'm wondering how complex the engine management electronics would be... can anyone point me to some good car-modding (VW in particular of course) sites? I know "modding" isn't the word car-modders use, what do they actually call it?
    Cheers for any info,
    ch424
  2. RepLiKa
    RepLiKa What's a Dremel?
    21 Aug 2004
    They call it 'Tuning'
    Strip it all out perspex windows etc and have fun lol
  3. milgo
    milgo What's a Dremel?
    12 Jan 2004
    Yeah just strip out all the excess like heaters, air conditioning etc. Put a straight through exhaust on it. It most likely has a small engine which doesnt have much potential.
  4. NiHiLiST
    NiHiLiST New-born car whore
    18 Aug 2001
    Strip out all the unneeded electrics, windows, carpets, rear seats etc. Depending on what state it's in he can probably sell a fair amount of the interior off to pay for some bits for the engine ;)
  5. ch424
    26 May 2004
    No no no, sorry, I didn't explain properly! We're making a new chassis, steering etc. All we want is the engine! I presume we're re-using the gearbox, but as it's front wheel dive, it'll need more than stripping for the engine to go at the back. What I'm looking for is info on VW engine electronics...
    cheers for the suggestions though!
    ch424
  6. Lynx
    Lynx What's a Dremel?
    24 Nov 2001
    What ever you do do not cut any part of the wiring loom untill you know EXACTLY what it does
  7. .308AR
    .308AR What's a Dremel?
    8 May 2005
    Leave the ecu and wiring intact. Waterproof the connections and ecu as much as you can. The complete front suspension/engine/transaxle/brakes welded to the rear of the new chassis will work fine. Just remove the steering and put adjustable tie rods in its place. You might want to get a VW bug front end.
  8. ch424
    26 May 2004
    Thought so :D
    Thanks peeps,
    ch424
  9. Fatboy
    Fatboy Bored
    8 Oct 2001
    Im having visions of that subaru go kart thats about the internet somewhere.
    2.0 turbo gokart buitl from an old impreza.
  10. profqwerty
    profqwerty What's a Dremel?
    2 Jan 2006
    Hello, kinda coincedence I was searching for info on said wiring loom and google threw up this thread :duh: . Yeah, I've taken out 2.5 of the 4 wiring looms, having taken note of where it all goes. It's all built in subframes - the engine/gearbox/dif/suspension/steering are all one unit bolted to the chassis by 6 large bolts. I'm using as much as I can, and will dump/ebay the rest. It's about 60hp (alex, wocm's is 6.5hp :naughty: ) so has a predicted top speed of about 400mph. most of the wiring is for the ecu, lights, so I can get rid of most of the sensors. There is no power steering/air con, so that simplifies it a lot. I will lock the steering wheels straight, and use that as one combined back axle. most of what i need is there - just need some steam pipe/thick ms, and a MIG welder. School shall provide...
    Have a great new year
  11. Freedom
    Freedom Minimodder
    27 Oct 2004
    GEt some photos up ere as soon as you start. Iam likeing the sound of this project.
