Apple Wake up MBP
Discussion in 'Software' started by Matt_y, 11 Apr 2007.
  1. Matt_y
    Matt_y What's a Dremel?
    4 Apr 2007
    Has anyone had a problem with getting their MBP to wake up from sleep mode. It is happening more frequently these days, but not due to anything specifically?
    Are there any suggestion on how to fix this ???
  2. Fod
    Fod what is the cheesecake?
    26 Aug 2004
    uh, no probs here. one issue though - if you wake the machine up by inserting/removing a USB peripheral it will take longer than usual to wake up, and this 'sticks' until you reboot. just remember to use lidwake.
    other than that, have you tried google? could be a service you are running.
  3. Gordy
    Gordy Evil Teddy
    17 Apr 2001
    I'm having the reverse problem, mine struggles going to sleep if you close the lid.
    Just outside its guarantee and there are other ways of making it sleep, so it's not a real problem.
  4. mookboy
    mookboy BRAAAAAAP
    15 Feb 2002
    This was an early and very common issue with the MBP. I had the same issue and it seemed to go away after one of the firmware updates released by Apple.
