Windows Wallpaper Manager?
Discussion in 'Software' started by :Galokin:, 16 Oct 2003.
  1. :Galokin:
    :Galokin: Guest
    ok im looking to get a program that changes wallpaper automatically on start up n stuff.
    It would be ideal if it was freeware plz.
    Just a list of the different programs n stuff would be good thanks.
  2. daniel_owen_uk
    daniel_owen_uk What's a Dremel?
    1 Sep 2003
    StyleXP does something called rotate, where you can rotate your themes backgrounds logon screens and visual styles.
  3. :Galokin:
    :Galokin: Guest
    ah one problem wiv style XP...i recently got rid of it cos it kept fudging up (excuse my french).
    I use window blinds but i dont think it does nething similar does it?
  4. BjD
    BjD What's a Dremel?
    10 Apr 2003
    I used to use a freware proggy imaginatively called wallpaper changer :thumb: Supports jpeg's, changes on starup, and every so many minurtes if you want, and also changes the icon background colour to match the wallpaper. Only problem i had with it is if it changes whilst burning a CD nero will fudge up resulting in coasterage. atm im just using a little VB proggy i did meself instead :rock:
  5. :Galokin:
    :Galokin: Guest
    ahh how cunning :D
    Ill check it out, thanks
  6. ndtinker
    ndtinker Car Washoholic
    23 Sep 2002
