Other Wallpaper stretch across 2 screens
Discussion in 'Software' started by LukeDaly, 9 Jan 2013.
  1. LukeDaly
    LukeDaly Pokemon Master
    9 Jun 2011
    Hey Guys,
    Got a second U2711 today and im looking for a way, to make a wallpaper stretch across both of the monitors , do I need 3rd party software or can windows do the trick?
    Also how do I make the start bar stretch across both monitors?
    Thanks in advance, Luke.
  2. Cookie Monster
    Cookie Monster Multimodder
    27 Aug 2003
    Its one of the options where you select the wallpaper within windows (picture position).
    Not sure on the stretching the start bar, I've taken to having a bar across the bottom of the wallpaper and setting my win7 start bar to transparent.
  3. longweight
    7 May 2011
    Windows 7 or 8?
  4. LukeDaly
    9 Jun 2011
    you sure I cant seem to get it to fit properly? :/
    7 mate :).
  5. longweight
    7 May 2011
    It isn't a default option, download Ultramon and use the 30 day trial :) Your wallpaper will stay as it is once the trial is over or you reinstall it from the .exe again and again.
  6. IvanIvanovich
    IvanIvanovich будет глотать вашу душу.
    31 Aug 2008
    You want one wallpaper that flows across both displays? You need to find some that are 5120x1440 or whatever. Usually easy to find panorama landscape shots like that, other things you will need to hunt.
  7. Deviate
    Deviate What's a Dremel?
    3 Jun 2002
    I used UltraMon for a bit then another program. Now I use Zbar. Allows multiple wallpapers, task bar on multiple monitors, etc. Oh...and it's free. :thumb:
  8. bigc90210
    bigc90210 Teh C
    7 Oct 2003
    displayfusion is pretty good too. esp for allocating 1 folder per monitor for galleries etc
  9. Adamski
    Adamski What's a Dremel?
    25 Jan 2013
    +1 on that. DisplayFusion works great with multiple monitors.
  10. VeNoM JaCKaL
    VeNoM JaCKaL L4D2 nom nom time!
    16 Jul 2007
    DisplayFusion and DualMon both free and display fusion has a website that provides dual monitor wallpapers as well in a variety of categories.
  11. Kovoet
    Kovoet What's a Dremel?
    26 Aug 2009
    I also find zbar easy to use and cheaper
