Modding want to make a huge lcd display
Discussion in 'Modding' started by bearair, 4 Jun 2005.
  1. bearair
    bearair What's a Dremel?
    11 Oct 2004
    i have 8 12 inch lcd displays that i want to convert into one large display(have the panels in a 2x2 2x2 set up) for one upter possible i was this webpage that made 2 virtual windows but what he did was way to specialize for his monitors to understand. the monitors are all normal vga inputs, so i was wondering how i can hook up the cables and what kind of hardware (video cards) i would need to run this dream project of mind. heres the catch i need to this on the cheap side (no extra cash laying around) any suggestions would be great, thanks in advance.
  2. Bboy_Jon
    Bboy_Jon Minimodder
    28 May 2004
    i think 4 5200's could work? i dunno
    5200's have 2 out puts right? (not including the s video or whatever)
    so just hook 2 monitors to each card, o ya and there pci cards
  3. Goldfish
    Goldfish What's a Dremel?
    4 Jul 2004
    If it were me I'd simply plug it into a video wall controller (you wouldn't need an expensive one, just one that supports the ratios you need for your screens) and run the video in from a decent graphics card (one with a VERY high VGA resolution) and bobs your uncle :)
  4. Blue Raven
    Blue Raven What's a Dremel?
    25 Sep 2003
    If you just get 2 graphics cards that have 4 monitor outputs (try the company matrox [I think that's how you spell it]), then you can just use windows to set all the monitors up as on big one.
  5. Bboy_Jon
    Bboy_Jon Minimodder
    28 May 2004
    dam 1 card with 4 outputs!!!!!!!! geez
    how many monitors can windows support?
  6. Smilodon
    Smilodon The Antagonist
    25 Mar 2003
    i THINK it's a maximum of 9.
  7. bloodcar
    bloodcar Minimodder
    1 Sep 2002
    I thought Matrox only made 3-head cards?
  8. InSanCen
    InSanCen Buckling Spring Fetishist
    30 Mar 2005
    The Matrox Parahelia is triple headed, IIRC, you want the G400/450/500 for Dual Head. Matrox do NOT make a 4 head card.
    The Parahelia is also bloody expensive for what is old hardware (I'd still love one though, Matrox always had lightning fast, Quality 2D)
    InSanCen
  9. tm36usa
    tm36usa What's a Dremel?
    21 Jan 2004
    Yeah, cant really play games on a matrox. But for 2d and Video Editing there isnt anything better.
  10. Smilodon
    25 Mar 2003
  11. bearair
    11 Oct 2004
    thanks for all the suggestions that gives me a good starting point
