HTPC Want to replace my sig HTPC
Discussion in 'Hardware' started by noizdaemon666, 1 Mar 2015.
  1. noizdaemon666
    noizdaemon666 I'm Od, Therefore I Pwn
    15 Jun 2010
    As per title guys. I feel my sig HTPC is way over specced for what it does. All it does is occasional Netflix and 1080p mkv playback.
    I was considering a raspberry pi but not sure it would handle the mkvs. They're encoded at CQ 15 on handbrake if that helps :)
    I've tried AMD AM1 gear but it didn't save me any space. Space and power use are the two things that I really want to reduce, space being the main one.
    Suggestions are all welcomed :)
  2. wolfticket
    19 Apr 2008
  3. IvanIvanovich
    IvanIvanovich будет глотать вашу душу.
    31 Aug 2008
    Look for used net top or thin clients with nvidia or amd graphics. They can often be picked up for pretty cheap and are perfect for htpc. Many are quite small and some of the better ones are even passive cooled. Most of the thin clients will absolutely need to have an ssd (or I suppose 2.5 hdd works too) as they tend to only come with tiny flash doms which are too small to be useful. There are also some thin client models that have internal pci-e slot so you could add a gpu if you can't find good price on something with nvidia or amd... though finding the case extender kits for them can be a different story. Or, newer Atom models that have intel HD graphics are up to the job too, but it's not as likely to find those on the cheap yet.
  4. faugusztin
    11 Aug 2008
  5. noizdaemon666
    15 Jun 2010
    I was hoping something less expensive faugusztin :p anyone used a Raspberry Pi 2?
  6. matiss
    matiss Member
    24 Jun 2010
    Friend of mine just got his Pi2 so no info yet on this one. But another one is using a Odroid which has about the specs of the Pi2 and he told me XBMC works without problems. I´ll ask him again tomorrow and the other one if he has news about the Pi2.
    Only thing about the Odroid is that it has less available software and could be more work depending on what you do with it.
    //EDIT:
    Just got a response, it's an Odroid C1 and he had no troubles with any video types so far.
  7. dhicks001
    dhicks001 New Member
    7 May 2011
    Intel NUC?
  8. noizdaemon666
    15 Jun 2010
    I considered a NUC but the lure of the Pi was strong. I've gone for the Pi2 just waiting for delivery now :D
  9. nimbu
    nimbu Well-Known Member
    28 Nov 2002
    My fire tv appears to be able to playback everything I have thrown at it so far....
  10. Nexxo
    23 Oct 2001
    ASRock Q1900TM-ITX. £95,--, thin ITX, works off a laptop adapter, passively cooled, CIR header, HTPC header. Handles 5 HD streams simultaneously without breaking a sweat. Everything you need, nothing you don't need.
  11. noizdaemon666
    15 Jun 2010
    Good shout nexxo but it's 3x the price of the Pi2. My Pi2 just got delivered :D A fun day ahead of testing stuff for me :yay:
  12. Nexxo
    23 Oct 2001
    Let me know how you get on. I always wondered how many HD streams a Pi can handle. I would have needed it to manage at least three.
