Windows Want to turn my PC into Movie Server
Discussion in 'Software' started by Neoki, 1 Nov 2012.
  1. Neoki
    Neoki Minimodder
    26 Oct 2004
    Hello,
    I would like to turn my PC into a movie server / Media server.
    What is the best software to do this.
  2. saspro
    saspro IT monkey
    23 Apr 2009
    mymovies.dk
  3. Fingers66
    Fingers66 Kiwi in London
    30 Apr 2010
    xbmc.org
  4. Neoki
    Neoki Minimodder
    26 Oct 2004
    Many thanks I have windows 7 Home Premium though. Will this cause any issues?
    I would like to play all my mkv files and utilize the 4tb of disk space i have
  5. Fingers66
    30 Apr 2010
    If you are going to keep Windows 7 on the PC and want to use it as a media server as well, then you should be able to do it with Windows Media Centre and DLNA?
    What are you going to be playing the movies on?
    If however you want to setup a dedicated PC as a media server, XBMC is the way to go.
  6. Neoki
    Neoki Minimodder
    26 Oct 2004
    The pc will not be used for anything else as I have my laptop.
    It depends what the best and easiest option is.
    PC in my sig is going to be the server/storage pool.
    Laptop will be what I view the films on.
  7. Neoki
    Neoki Minimodder
    26 Oct 2004
    How does XBMC compare to MyMovies
  8. Fingers66
    30 Apr 2010
    There is a simple way to do it, simply install VLC on your laptop, enable the sharing of your movies on your desktop PC and play the MKV files directly.
  9. Neoki
    Neoki Minimodder
    26 Oct 2004
    Hmm true or network drive i guess but I would like it to look all nice with details about the films etc.
  10. saspro
    saspro IT monkey
    23 Apr 2009
    My movies does that & integrates with media centre so you can use a remote control if you wish
  11. dancingbear84
    dancingbear84 error 404
    16 Oct 2010
    Plex is what I use. It is great. I hadn't heard of my movies but it looks interesting.
  12. Andy Mc
    Andy Mc Modder
    23 May 2002
    XBMC. Always.
  13. Ferino
    Ferino Minimodder
    26 Mar 2010
    Have to jump on the xbmc wagon here. Read about it in another post on here somewhere, played about with it, then within a few weeks had built a htpc for the living room just to run it. Awesome bit of software and i'm just starting to scratch the surface.
