Modding wanted: 1mm round aluminum mesh
Discussion in 'Modding' started by Kickn, 2 Aug 2004.
  1. Kickn
    Kickn What's a Dremel?
    7 Oct 2003
    Does anyone know where I can buy something like this in the uk:
    Thanks ;)
  2. Mister_Tad
    27 Dec 2002
    kustompcs sell it
    they charge an arm and a leg for it mind you
  3. Kickn
    7 Oct 2003
    ya well I was looking for a more 'economical' source :)
  4. ehrnam45
    ehrnam45 What's a Dremel?
    5 Jul 2004
    try mcmaster-carr (www.mcmaster.com) I think they ship internationally. look under perforated materials in the "raw materials and springs" paragraph at the bottom of the page. the cost per sheet is kinda high (US$80) but that's for a sheet almost a meter square, and stainless steel too. they offer lower grades of steel and even brass and aluminium, which are cheaper. mayhap you and a few mates could pitch in on a sheet and split it up.
    Mmmh, they offer a neat hexagonal pattern too... could be a good theme for a mod?
  5. BlackMan
    BlackMan Minimodder
    12 Sep 2003
    try your local metal shop, i found a sheet 2x4 meters for $28, at shoesteel, you could even try the dump
  6. cogitoergosum
    cogitoergosum What's a Dremel?
    14 Jul 2004
    I agree with the dump idea. Also check all the random appliances you have around the house. Microwaves are a good source of mesh (just don't tell the parents/wife and stay away from the microwave while its operation!)
  7. LiL_MJ
    LiL_MJ What's a Dremel?
    4 Nov 2003
    halfords! will cost u around £20 as its car mesh and only in large sheets
  8. Kickn
    7 Oct 2003
    LOL - that stuff is like 5mm mesh - maybe even bigger if I remember.
    I need 1mm stuff - like on the front of my coolermaster 410 or the V1000 case.
  9. LiL_MJ
    4 Nov 2003
    y not buy som cheap aluminium sheets that are 1mm then use a holepuncher?
  10. Kickn
    7 Oct 2003
    because I need sheets of it and don't fancy making 1000's of 1mm dia holes :wallbash:
