Case Mod - In Progress Warcraft Themed 750D Case Mod! (FEL MAGIC)
Discussion in 'Project Logs' started by Imfaceroll, 22 Aug 2016.
  1. Imfaceroll
    Imfaceroll What's a Dremel?
    27 Jun 2014
    Hey everyone and welcome to another build of mine! Today i would like to share with you my warcraft themed PC build which will be given away on my youtube channel.
    www.youtube.com/imfacerollpcgaming
    www.facebook.com/imfacerollgaming
    SPECS
    MSI Z170A-Gaming Pro Carbon Motherboard
    MSI GTX 970 GPU
    Intel I5 6600K
    Corsair Dominator Platnium RAM 16GB
    Corsair HX 750I PSU
    Corsair Neutron XT SSD
    A massive thank you to Corsair and MSI for supporting this build!
  2. Imfaceroll
    27 Jun 2014
    Here is progress 1 to our warcraft PC. Today we will be creating a PSU cover/reservoir. The idea here is to make the dark portal from World of warcraft and make a reservoir out of it. At the bottom of the stairs i also want to create a cracked ground which the green liquid will represent fel magic!
    I started with some 15mm thick acrylic and used a jig saw to cut it to siz, then filed and sanded it smooth to remove the jigsaw cut marks.
    Now i needed a top plate so that i could seal the reservoir tight!
    Time to route out some material to create the water channel
    and here is the look i am going for, the ground will have cracks like in the images below and the portal will be standing upright
  3. Imfaceroll
    27 Jun 2014
    Progress 2 today. Today I create the portal columns and i Tap some holes in the reservoirs for my fittings.
    As you can see here i have drilled some holes and tapped the threading in for my fittings.
    I have created the columns for the portal which simply slide together to make installation very easy.
  4. Imfaceroll
    27 Jun 2014
    Today is progress 3. Today we get into the details of the reservoir, starting to take some shape and we are happy with how things are turning out.
    I wanted to test out our reservoir to make sure there were no leaks
    Next step i cut out some vinyl for our warcraft sign and applied it, next we went over the sign with some body filler.
    Time to apply those cracks in the ground to our reservoir!
    Lets prime everything getting it ready for paint!
  5. Imfaceroll
    27 Jun 2014
    Progress 4 today. Today we start painting our custom reservoir and the portal!
    I applied some body filler around the cracks to create some texture to the ground
    I created the stairs and primed them as well as the reservoir
    Time to apply our aged copper base coat and get started with air brushing!
    Final result after painting!
  6. Hukkel
    Hukkel James' minion
    20 Dec 2012
    Nice work on the reservoir.
    Do you own your own CNC?
  7. Imfaceroll
    27 Jun 2014
    hey man, yeah i just got one, its the xcarve, a nice cheap starter CNC, its cheap because you have to build it yourself.
  8. Imfaceroll
    27 Jun 2014
    WARCRAFT PC COMPLETE!
    Today i bring you the final shots of my warcraft PC! I f you enjoy please feel free to check up on more builds of ours over at:
    I would now just like to thank MSI and Corsair once again for their participation in this build and i will now let all of the photos do the rest of the talking!
