Scratch Build – In Progress Wargames WOPR desk computer
Discussion in 'Project Logs' started by HCP, 5 Nov 2012.
  1. HCP
    HCP Member
    19 May 2012
    From the movie Wargames i bring you WOPR.
    Love this movie, and love the WOPR.
    Started planning this a half year ago, tried to contact people in the US having some info about the real model to get measurements and color codes etc.
    Got some good info and now its time to get it rollin´.
    I found some sketchup model of the WOPR, but the measurements were totally off, and some parts were to big/small, wrong place and so on. Took me almost a month to get all details right in the sketchup model. Used the movie of course and all pics i could found on the net. Also got some emailed to me from a previous worker who made the original back in the 80´s.
    Size of the case will be about 19x8x6", perfect to house a ITX motherboard with a (hardware is changing, Nov. 2014)
    I do not play games, so the graphic power is not a issue for me.
    If someone dont know what the WOPR is.
    War Operation Plan Response
    Now from the start, it may look a bit messy until i get all the parts and stuff together
    The roof of the WOPR. Rounded wood stripes to get rounded parts without sanding me to death
    Adding some round corners, Using 20mm pipe to get perfect corners.
    The three panels for the LED´s
    Sketchup model, got them CNC cut to get perfect holes everywhere
    My first order of LED´s, 400 of them... After some counting, im gonna need 1000 more :)
    To be continued
  2. Vetalar
    Vetalar *learning english*
    21 Jun 2011
    when i thought about led array - i find smth like this
    it's dirt cheap, no need to solder or smth. just drill holes and put leds randomly
    and it blinks in 8 ways :)
  3. HCP
    HCP Member
    19 May 2012
    Im using a solder kit from Velleman to control the lights, christmas lights i think will ruin the result with blue and green lights :)
  4. Vetalar
    21 Jun 2011
    there is alot of lights on market of any desirable color. oh and one cut away blue/green lights :)
  5. HCP
    HCP Member
    19 May 2012
    Now when i think about it, the flash sequence is pretty much spot on with the WOPR, looking at my neigbours house lights.
    But, already soldered 400 leds. Maybe use the christmas lights for the back side nobody see anyway :)
  6. HCP
    HCP Member
    19 May 2012
    Now it starts to look like the WOPR :)
  7. Vetalar
    21 Jun 2011
    one have a ton of patience :D
  8. C4B12
    C4B12 Minimalistic PC's
    6 Oct 2011
    This is gonna be fun to follow. Love that old movie!
  9. HCP
    HCP Member
    19 May 2012
    After some re-measuring, the first part i made for the LED panels was to small. Forgot to change the setting on my table saw :)
    Trying to hold all pieces for a photo :)
  10. HCP
    HCP Member
    19 May 2012
    Slowly growing up :)
    sorry for the mess around the bench, i dont have time to clean up for the pics ;)
    Of course there will be some descent final pics and video of it.
  11. HCP
    HCP Member
    19 May 2012
    Been sanding and sanding to get straight edges and round corners.
    The top parts getting good now, and ready for gluing. But i think i leave some parts to the last step so i dont get any problems adding the electronics :)
    Adding a pic of the real deal, from almost the same angle.
  12. Ch2pa
    Ch2pa New Member
    28 Aug 2012
    I will follow this one :)
    I like the concept and the movie too. Good Luck :thumb:
  13. Pfaffen
    Pfaffen New Member
    18 Mar 2007
    Never thought of Christmas lights, how much power do they use? Voltage and Amperage?
  14. kelmannen
    kelmannen New Member
    5 Feb 2011
    usually 12/24v, amperage totally differs with the lenght/voltage
  15. Pfaffen
    Pfaffen New Member
    18 Mar 2007
    Thanks! I may have to try that sometime.
  16. Nexxo
    Nexxo Queue Jumper
    23 Oct 2001
    HELLO HCP. SHALL WE PLAY A GAME?
    >_
  17. C4B12
    6 Oct 2011
    @nexxo It's "Greetings HCP" actually ;)
  18. Hanoken
    Hanoken O.O
    12 Jul 2012
    I thought for a sec you were hinting at warhammer my bad ha ha ha, but to say the least now that I realize it is a mod about wopr I'm even more interested :) can't wait to see what you have in mind for this project, by the way, ever heard of a game called defcon? you might be interested :)
  19. HCP
    HCP Member
    19 May 2012
    My biggest concern with the WOPR was the doors, they are countersunk and have rounded edges.
    Take a look
    I tried different solutions, cut open pipe, sanding in a angle and other stuff, nothing really good.
    Now i found this, and whats im going with. Not 100% identical with the original but good enough.
    Some putty and sanding, and after that i will run a router bit making the edge rounded i think will do the job.
  20. HCP
    HCP Member
    19 May 2012
    Now the fun work starts :)
    Time to figure out where the LED´s go, from what cluster and what colour, my charts are pretty easy to follor, but with 1400 LED´s i think i will have a brain freeze or two :p
