Motors Washed key fob!!!
Discussion in 'General' started by phinix, 9 Jul 2013.
  1. phinix
    phinix RIP Waynio...
    28 Apr 2006
    I didn't take battery out yet.
    It is glued together, didn't want to break it.
    I'll keep it in bag of rice for today, tomorrow will try and put it in oven for lowest temp for a minute:eeek: maybe even opened oven door, just in case I toast it;)
    Then I will try it out.
  2. phinix
    28 Apr 2006
    Are you sure?
    The one I have is glued together so cannot simply take it apart.
    Maybe its waterproof then? We'll see when I try it out:thumb:
  3. phinix
    28 Apr 2006
    In this case a little pray is in place....:worried:
  4. julianmartin
    julianmartin resident cyborg.
    25 Jul 2004
    TheBlackSwordsMan Far over the misty mountains cold
    16 Aug 2009
    Shouldnt these be waterproof ? Keys are the kind of things that folks easily forgot before pressing 'start' on the washing machine.
  6. David
    7 Apr 2009
    ..or dropped in a puddle whilst entering/exiting the car.
    Tyinsar likes this.
  7. phinix
    28 Apr 2006
    Guys, you are giving me some hope! :)
    Do you think I should try it out tonight? It has been in a bag of rice since 12am.
    Should 20 hours be enough to test it?
  8. julianmartin
    25 Jul 2004
    Do it. Do it now. I think it'll be fine.
  9. Modsbywoz
    Modsbywoz Multimodder
    14 Oct 2009
    You could always put it back in the bag ya'know.
  10. BentAnat
    BentAnat Software Dev
    26 Jun 2008
    Worst case: it explodes and you lose a key fob, a hand, both eyes and your sanity... /troll
    Seriously - worst case you fry the keyfob.
  11. Carrie
    Carrie Multimodder
    18 Nov 2010
    Well my sky remote survived falling into a glass of berocca and being in there for about an hour! Just opened it up, took it apart, dried it with paper towels and a gentle fan dry and it works better now than it did before - must be the added vitamins :hehe:
    David likes this.
  12. Matticus
    Matticus ...
    23 Feb 2008
    Unless you actually need to use the key/car then I would just leave it to dry out for as long as you possibly can.
    I have had great luck with electronics and water, firstly by not having many accidents and when I do, always leaving them for as long as possible and immediately removing the battery (obviously not possible in your case) especially if it is something "active" like a phone.
    My girlfriend is a nightmare with water and things that shouldn't be in water, her old iPhone survived many baths and toilet trips. Dropping the end into lemon curd finally finished it off :duh:
  13. Harlequin
    Harlequin Modder
    4 Jun 2004
    I went swimming with my espace key - on the same key ring was my wow authenticator....1 out of the 2 survived the experience...
  14. §§...
    §§... What's a Dremel?
    19 Mar 2003
    Here's one i prepared earlier
    DO NOT DO THIS TO YOUR KEY!
    Just to give you an idea on it's water-tightness; seems pretty waterproof to me, i think you'll be OK
  15. Big_malc
    Big_malc Minimodder
    7 Sep 2010
    the fob not normally that expensive its the key number and programming it were you wont the lube
  16. RinSewand
    RinSewand What's a Dremel?
    11 Sep 2006
    I'd go with leaving it as long as possible, it's one thing being waterproof, but quite another surviving a washing machine.
    In terms of price my malfunctioning Audi key was invoiced at £349 to replace. Thankfully I wasn't paying..
  17. Unicorn
    25 Jul 2006
    The **** is a wow authenticator?!
  18. legoman
    legoman breaker of things
    28 Feb 2010
    Think its a bit like this which is a secure network access key i have one fore work when im offsite so i can access our servers
    Also those keys are meant to be water proof so fingers crossed
  19. Teelzebub
    27 Nov 2009
  20. Gaming_freak_10
    Gaming_freak_10 Minimodder
    5 Jun 2010
