Water Alien Rebirth - From Brazil
Discussion in 'Project Logs' started by pedrofilho, 18 Apr 2007.
  1. GAM
    GAM What's a Dremel?
    15 May 2007
    Happy Birthday Pedro! (you're a few months ahead of me ;))
  2. pedrofilho
    pedrofilho What's a Dremel?
    4 Apr 2007
    Thank you very much GAM !! You're beating the 40's doors too?
    See you soon,
    Pedro Torres.
  3. pedrofilho
    4 Apr 2007
    Working on front panel plexi-glass window:
    Bending the borders:
    Bended:
    The other side:
    Bending the middle:
    Done:
    Almost there:
    After a few adjustments, the result:
    Fits perfectly.
    See you tomorrow with more news.
    Pedro Torres.
  4. jokkos
    jokkos too busy to mod *sigh*
    10 May 2005
    nice bending work on the plexi, the front panel is turning out very well!
  5. pedrofilho
    4 Apr 2007
    Thank you very much jokkos, I appreciate your support.
    Thanks,
    Pedro Torres.
  6. Bilbo Fraggins
    Bilbo Fraggins What's a Dremel?
    1 Jul 2004
    looks good, keep it up! :dremel:
  7. pedrofilho
    4 Apr 2007
    Thank you very much Bilbo. Tomorrow I'll finish the front panel and start the wire management. Keep watching.
    See you,
    Pedro Torres.
  8. pedrofilho
    4 Apr 2007
    Exterior texture starts:
    Black base:
    Tomorrow I’ll do the texturing paintings and bring the photos.
    See you,
    Pedro Torres.
  9. pedrofilho
    4 Apr 2007
    Texture paintings:
    First of all, fix some irregularities of UFO surface:
    The first part to be painted:
    First layer, Prussian blue:
    After a second and third layer, titanium white and ochre:
    The upside:
    Prussian blue:
    Work done, with flash:
    Tomorrow I’ll paint the UFO and it’s side panel.
    See you,
    Pedro Torres.
  10. pedrofilho
    4 Apr 2007
    UFO and it’s side panel painting:
    First layer, Prussian blue, the UFO was painted in silver:
    Second layer, titanium white:
    Third layer, ochre:
    Strobe flash
    This paintings takes 5 days to dry completely, after that, I’ll mount all the case.
    See you there,
    Pedro Torres.
  11. MikeK
    MikeK What's a Dremel?
    6 Feb 2005
    Looking great Pedro!!
    Good luck with the rest of the case. :thumb:
  12. pedrofilho
    4 Apr 2007
    Thank you very much Mikek, the rest of the case will be done really soon. I want to mount it in 5 days.
    See you there,
    Pedro Torres.
    BTW-> Have you voted on this thread already?
  13. MikeK
    6 Feb 2005
    Have done it now!!
    Can´t wait to see the finished result! :thumb:
  14. pedrofilho
    4 Apr 2007
    Thank you for your support Mikek, I appreciate that. Until saturday it will be mounted.
    See you soon,
    Pedro Torres.
  15. hu$tla
    hu$tla What's a Dremel?
    19 Jun 2007
    looks good i i like the roughness of the painting :)
    Cant wait to see more keep up
  16. pedrofilho
    4 Apr 2007
    Thank you very much hu$tla, have you voted on the thread?
    I'll mount all the case really soon, until saturday it'll be done.
    See you,
    Pedro Torres.
  17. pedrofilho
    4 Apr 2007
    Case feet repair and internal side panel painting:
    During the texturing I let some body filler escape to the plexi-glass and, now, had to repair it:
    First, I removed the excess of body filler with the Dremel sander:
    Finished one:
    Got this:
    Sanded one by one with 150 paper to remove every body filler traces:
    Used the polishing Dremel bit with silicone to smooth the border and get a nice shiny:
    In action:
    This is the result of polishing:
    Then I painted the scratched areas using the same colors:
    Ochre:
    Repair done:
    All the feet painted and waiting for the titanium white with a dry paint.
    Final result:
    The ET side panel interior was a mess of colors, so, I decided to paint it in chrome to help the illumination:
    This is the result (really shiny, mirror finishing):
    That’s it for now. Be back soon.
    See you,
    Pedro Torres.
  18. Guest-2867
    Guest-2867 Guest
    This one totally slipped past my radar, just read the whole thread and there's some really cool ideas, very nice work indeed, I like the theme!
    Keep it up man, it'll be nice to see how this all works toghether when it's finished :D
  19. pedrofilho
    4 Apr 2007
    Thank you very much dire_wolf, glad you liked it. Also, thanks for the vote on the thread. Is really nice to get support for your project.
    Tomorrow I'll be working on cables and sleeves. Keep watching. The mounting process may happen this weekend.
    See you,
    Pedro Torres.
  20. MikeK
    6 Feb 2005
    Great work on the feets Pedro!
    I really like the looks on them, good luck with the rest of the building!!
