Graphics Water block gtx 480
Discussion in 'Hardware' started by will_123, 25 Feb 2011.
  1. will_123
    will_123 Small childs brain in a big body
    2 Feb 2011
    In the process of fitting my water block on gtx 480. But there are plastic black heat sinks on RAM which i cant seem to move any advice regarding these all the screws are out on the back?
    Any advice would be great thanks!
  2. will_123
    2 Feb 2011
  3. thetrashcanman
    thetrashcanman Angel headed hipsters
    18 Nov 2010
  4. mars-bar-man
    mars-bar-man Side bewb.
    17 Apr 2009
    Gently twist them, and they should come right off.
  5. Bloody_Pete
    Bloody_Pete Technophile
    11 Aug 2008
    The thermal pads can create a bit of a vacume and 'stick' in place. Just gently twist the block (horizontaly) and warm it up a little :) Took me 20 minutes of softly twisting and warming to remove the heatsink on my 5870.
  6. Blarte
    Blarte Moderate Modder
    15 Jul 2008
    just had to buy a Torx size 6 star driver to remove the screws from the back of a Evga 580GTX .. I was having kittens sweating over it .. as on one card they blue glued em in .. (turds)
    B.P.... did you manage to get them off okay?
  7. will_123
    2 Feb 2011
  8. Blarte
    15 Jul 2008
    Oooohhh they do look nice all shiny ...
  9. Mattmc91
    Mattmc91 Minimodder
    18 Oct 2009
    i just put the card into the pc, boot it for 1 second, and they're all warm and toasty and fall off quite easily.
    EDIT: Or even better, have an intense gaming session before you dissemble the card for a couple of hours, it makes it nigh on instant to come apart!
  10. Baz
    Baz I work for Corsair
    13 Jan 2005
    EK Block w.compression fittings - noice.
  11. dead beat
    dead beat Rippin six 4 life
    15 Feb 2009
    Both my 580's came apart beautifully. It was installing all the thermal pads that was the pain.
  12. Bloody_Pete
    11 Aug 2008
    And remembering to take off both sets of protective coverings... I nearly forgot :p
    All my 5870 screws where just mini phillips screws.
  13. will_123
    2 Feb 2011
    Case just arrived just now everything is set. Might start another post and start posting some pictures.
  14. dead beat
    15 Feb 2009
    Ha, yes cutting the pads and peeling off those layers is a LONG process.
    I actually prefer the torx screws as you have less chance of stripping them when taking them apart/putting back together (I've never liked phillips screws). Bit annoying if you don't have a torx set though.
  15. thetrashcanman
    18 Nov 2010
    look forward to it :D
