Modding Water cooled fan
Discussion in 'Modding' started by acerhater, 18 Apr 2003.
  1. acerhater
    acerhater What's a Dremel?
    21 Jan 2003
    I ran across this fan while checking out some web sites. Can anyone tell me if they have seen (or used or heard of) this before.
    Sure is unique looking, I just wonder if it really works or not. Also it says the pump is magnetic, would that screw with the cpu or not?
  2. hydrogen18
    hydrogen18 Banned
    19 Jun 2002
    this cooler is ****. ABSOLUTE POS. It offers none of the advantages of watercooling. Do not buy it. There is already a thread about this somewhere....
  3. acerhater
    21 Jan 2003
    Thanks, I had my doubts about it but ya never know, I have been fooled before thinking something wouldn't work and it did. Figured if I asked around someone would know.
  4. wywywywy
    wywywywy Minimodder
    26 Sep 2002
    There is a review on moddin.net I think.
  5. BoCoMoFo
    BoCoMoFo What's a Dremel?
    30 Sep 2002
    I see no reason for that 'thing' at all. If you want to watercool, then just learn how to do it, save some money, and do it yourself. The liquid in that 'thing' would just get hot, anyway, and I don't see any way to cool it.
    What a waste of engineering hours.... :rolleyes:
  6. Smilodon
    Smilodon The Antagonist
    25 Mar 2003
    i can't reason for it to actually work.. first: the heatsing is so small that it would fit on the CPU anyway... second: there is so little liquid in it so it would be wery hot wery fast anyway... third: if this DO work.. it would still transfer the heat inside in the case.. and not outside (top) to you would still need just as many casefans...
  7. bradford010
    bradford010 Bradon Frohman
    7 Dec 2001
    Still being advertised on the front page, though I see :eyebrow:
  8. mashie
    mashie The one and only
    15 Mar 2002
    A very interesting review can be found here.
  9. Interesting indeed. LOL :lol:
  10. DeX
    DeX Mube Codder
    22 Jul 2002
    Wonder why he didn't try it on a real CPU. 0.62C/W or 62C isn't that bad. :rolleyes: Maybe for watercooling but it can hardly be called watercooling....
  11. Der Me!$ter
    Der Me!$ter What's a Dremel?
    14 Sep 2002
    I read a German review about it. It SUCKED... It was worse than most plain air coolers, definately not a good buy! All of these companies are trying to make watercooling mainsteam and are creating the crappiest products. These cheap-o products, like the ones, which fit in drivebays, etc. are worthless in my opinion. Rather get a large aircooler or invest in some quality water cooling and don't waste your money!
  12. jetsetjimbo
    jetsetjimbo Up-up and away
    19 Feb 2003
    IMO you might as well just buy a decent heat sink :)
  13. Tribal Dragon
    Tribal Dragon Insomniac modder!
    17 May 2002
    what the **** is that?
    I mean... there's no logical reason for that thing to exist... lol
    ah well... I'm sure some people will get it :worried:
