Modding water cooled Lian Li
Discussion in 'Modding' started by 2800@2.5ghz, 23 Mar 2005.
  1. 2800@2.5ghz
    2800@2.5ghz What's a Dremel?
    23 Mar 2005
    project water cooling complete, well......almost.
    all i need now is a fan controller to tame that beast of a panaflow currently at 12v pushing 103.8 CFM@2400RPM with a shocking 41.5 dba
    Temps: Idle 32 degrees C
    Prime 95:47C (amb.23)
  2. 2800@2.5ghz
    23 Mar 2005
    Update
    added a small fan to voltage regulators n covered up the mobo power connector with some shrink wrap and black tubing
  3. Headspark
    Headspark Minimodder
    23 Feb 2005
    get some dye in those tubes!!
  4. metarinka
    metarinka What's a Dremel?
    9 Feb 2003
    I'm confused why would you put A tee in a watercooling loop? from what I can make the pump goes straight to the cpu block then tee's and after that it gets hazy I could see using a Y to halve the pressure but double volume but a t would just descrease the flow rate to everything
  5. Headspark
    23 Feb 2005
    isnt the t allowing him to use a fill tube, which is just coiled up, up there.
