Notebooks Water Cooling A laptop?
Discussion in 'Hardware' started by timothyw9, 27 Feb 2006.
  1. timothyw9
    timothyw9 Banned
    26 Feb 2006
    i know this sound s mad but is it possible to water cool a laptop.
  2. Glider
    Glider /dev/null
    2 Aug 2005
    Possible? Everything is possible if you set your mind to it... Usefull is a whole different question.
    And even if you pulled it off, it would severly enlarge the laptop, and make it heavier, so the whole portable idea get's quite a dent.
    But if you pull it off, respect ;) :dremel:
  3. Valo
    Valo Minimodder
    11 Aug 2004
    hmm
    there are those, pump-block-res in one + radiator kits... might be possible... but seems quite pointless, but still that would own to have, i already have ideas of res in the back of lcd, etc... mm... rockage.
  4. mp3god
    mp3god What's a Dremel?
    27 Feb 2006
    I once read about an actual water cooled laptop that was being shown off at an asian consumer electronics show. Wish I could remember more, but the resevoir was incorporated into lid behind the screen! I think it was a korean brand but im not sure
    It might have been a dream or hoax, though!
    EDIT:.......................................................................
    maybe not, good old google gave me this...
    http://www.pcworld.com/news/article/0,aid,102779,00.asp
    here's the google search:
    http://www.google.com/search?source...GL,GGGL:2005-09,GGGL:en&q=water+cooled+laptop
  5. Nexxo
    23 Oct 2001
    It has indeed been done --at a prototype level. The unit consisted of a tiny pump, block and radiator in a flatbed frame layered over or under the PCB; there was no reservoir. This was before heatpipes became popular and I think it was abandoned when it became obvious that more conventional air cooling with heatpipe technology was just as effective.
  6. Confused Fishcake
    Confused Fishcake Minimodder
    25 Sep 2005
    Think what it would do for battery life...
  7. 731|\|37
    731|\|37 ESD Engineer in Training
    5 Sep 2004
    umm kill it? instead of powering two fans it would probobly power one and then a pump. I dont see it as being battery effective
