Cooling water cooling a shuttle
Discussion in 'Hardware' started by Burnout21, 28 Nov 2005.
  1. Burnout21
    Burnout21 Is the daddy!
    9 Sep 2005
    hey guys got a question, i wait to set up a loop in a shuttle believe its a SN145G2? so i would like to know wat the smallest pump, block i can get? iv got a 80mm black ice rad lieing around will that on its own be good enough, iv got a XP-M 2500 to put in it and i know that will drop the temps at stock speeds and volts, may even push it back up to 2.4GHz?
  2. AWACS
    AWACS What's a Dremel?
    10 Jun 2005
    laing ddc should be the smallest pump on the market
  3. M_D_K
    M_D_K Minimodder
    3 Apr 2002
    Go 10mm it will be easy to cool, probably a lang or a C-MAG would do the job
    morgan.
  4. Atomic
    Atomic Gerwaff
    6 May 2002
    I've got a Xice Socket A block thatll take 10mm tubing for sale if your interested...
  5. Burnout21
    9 Sep 2005
    how much for that block?
  6. Atomic
    Atomic Gerwaff
    6 May 2002
    £30inc sound ok? Its a heavy bugger!
    Don't live in Norwich by any chance?
  7. Nexxo
    23 Oct 2001
    Any small-bore system will work nicely. An 80mm fan rad will not be enough for cooling though.
  8. Leeum
    Leeum What's a Dremel?
    16 Feb 2004
    Agreed, I'd try and make an aluminium bracket or something similar to hold a BIX onto the back.
  9. Burnout21
    9 Sep 2005
    i will wait until it arrive and make my decisions when i get an idea on how big it is?
  10. Burnout21
    9 Sep 2005
    it is a xpc SN41G2, that is on its way. is there a way of mounting a rad in the top with moving the PSU and still being able to use the 5 1/4 bay?
  11. Atomic
    Atomic Gerwaff
    6 May 2002
    You can mount a single 120mm rad off the back of the shuttle if you build some custom mounting plates.
  12. phuzz
    phuzz This is a title
    28 May 2004
    Four holes and some long stand-off's would be enough...
    Or you could go for a large passive radiator like the Zalman reserator, Just fit the blocks and route the hoses out the back, easy as.
  13. Burnout21
    9 Sep 2005
    i like that idea, bit of a side track here, the shuttle has a 250w PSU and iv got a 68gt to put in it. now are these PSU any good? coz there is alot of 650w OMG look at at my flashy lights etc but there about as good as a 300w even less.
  14. Atomic
    Atomic Gerwaff
    6 May 2002
    The shuttle PSU will take everything you can fit in a normal shuttle.
    It is no cheapie pos!
  15. Burnout21
    9 Sep 2005
    how about the coolmaster aquagate? its prefilled and the load wont be that high coz its only cooling a xp-m.
  16. Nexxo
    23 Oct 2001
    Should work, but can it squeeze inside a Shuttle?
  17. AWACS
    10 Jun 2005
    don't think so... the 80mm version might... but then again it's not upgradeable
  18. Burnout21
    9 Sep 2005
    i just got to look at my shuttle, only a glace and it looks as if i can fit a 120mm rad in it at the top, what i am pissed about is i cant use my artic cooler on my 68gt!
  19. AWACS
    10 Jun 2005
    pffft... water cool it aswell if you're going to watercool
  20. Burnout21
    9 Sep 2005
    will a single 120mm handle that amount of heat?
