Modding Water cooling advice!
Discussion in 'Modding' started by jrf23, 9 Sep 2008.
  1. jrf23
    jrf23 What's a Dremel?
    1 Sep 2008
    Hey guys I'm new to the forum and need some advice on water cooling to try and puch my OC further. I haven't looked into it at all so any good guides etc would be appreciated!
    Cheers
  2. DaveVader
    DaveVader Fast Action Response Team
    10 Aug 2007
    Anything you want to specifically know?!
    You seem very eager as you have done your research, oh sorry, that says "haven't looked into it"
    That's the first port of call. Use Google, Watercooling shops to get an idea of products on the market. Don't use kits. I repeat, do NOT use kits.
    But like I said, anything specifically you want to know?
  3. teamtd11
    teamtd11 *Custom User Title*
    31 Aug 2005
  4. zr_ox
    zr_ox Whooolapoook
    5 Jan 2005
    Sorry dude but thats not the case anymore! Swiftech, Danger Den and EK do kit's which provides the perfect entry point to the world of water.
    OK you cant tailor a kit the same way you would by cherry picking the best components but something like this:
    Swiftech:
    http://www.swiftnets.com/products/H20-220-APEX.asp
    Danger Den:
    http://www.dangerden.com/store/product.php?productid=333&cat=65&page=1
    EK:
    http://ekwaterblocks.com/shop/product_info.php?cPath=23&products_id=84
    None of these will offer the same performance as something you have chosen yourself, however both Danger Den and Swiftech allow you to custom build the kit. Kit's take all of the guess work out of watercooling for the first time, which can be nice when your starting out!
    p.s. I just got the new Apogee GTZ which is GREAT! (buy that for the CPU) Overall I would suggest the Swiftech kit/s
