Cooling Water Cooling Help
Discussion in 'Hardware' started by bushd, 13 Jan 2005.
  1. bushd
    bushd What's a Dremel?
    9 Nov 2002
    Ok, i have never done water cooling before, and im trying to find the best parts to use for it. I have looked at the water cooling link thread but, i wanted to get somebody who knows water cooling and has used it to give me sorta like a full parts list of some of the best stuff there is to use :D
  2. BlackDiamond
    BlackDiamond What's a Dremel?
    7 Sep 2004
    Go to procooling.com and look at the stuff people there have/recommend. Normally a swiftech/TDX block, D4/Eheim/Iwaki pump, clearflex/tygon tubing and auto heatercore.
    IMHO it all depends on funds and what your goal is (bling/silence/overclocking).
    Enough to get you started...
  3. fivecheebs
    fivecheebs Dont panic!
    19 Feb 2003
    Indeed, you really have to do your own research when you watercool IMO.
    There are so many variables, everyones reasons for watercooling are different, and everyones tastes are different. Componant (rad and res) choice depends on the case and how much modding you are prepared to do.
    Have a look through the watercooling galery and tell us what you like the look of. Give us some system specs and we will point you in the roight direction...
