Modding Water Cooling my GPU
Discussion in 'Modding' started by Theoroshia, 22 May 2011.
  1. Theoroshia
    Theoroshia What's a Dremel?
    22 May 2011
    Quick question: I've begun looking into water cooling my GPU for a mod that I'm planning on doing, but I can't seem to find any water blocks that are compatible with my graphics card. It's an NVIDIA GeForce GTX 260. I've tried Google, and Newegg, but results are sparse and the information provided on them is often times oddly worded or confusing to a first time water cooler like me.
  2. lancer778544
    lancer778544 Multimodder
    5 Jan 2011
    Aquatuning stock two GTX 260 compatible full cover waterblocks, one for the G200 revision, the other for the G200b
    I think GPU-Z should be able to tell you what revision you have. I hope this helps :)
  3. Theoroshia
    22 May 2011
    GPU-Z helped a lot, thanks! However, it appears Aquatuning doesn't ship to the United States at all. Do you know of any other suppliers that will?
  4. IvanIvanovich
    IvanIvanovich будет глотать вашу душу.
    31 Aug 2008
    i recommend ek blocks. you can go here to see which options for your particular card. you can buy from them direct, but sadly they don't always have the best prices.
  5. lancer778544
    5 Jan 2011
    No problem, glad to be of service :hehe: Heres the links to the Aquatuning U.S site: G200 G200b
    Performance-PCs also stock some EK GTX 260 blocks though I can only find G200b versions: 1 2 3 4
    I don't know of any other U.S based watercooling shops but I'm sure someone else on these wonderful forums will be able to help :lol:
  6. Big_malc
    Big_malc Minimodder
    7 Sep 2010
