Cooling water cooling research
Discussion in 'Hardware' started by Gajdycz, 7 Jan 2005.
  1. Gajdycz
    Gajdycz Banned
    25 Nov 2004
    just soem odds and ends...
    1 radiator shrouds, are they needed?
    2.clamps for the tube connections, useful they are?
    3.mixing water blocks, im going for asetek, but im getting a danger den cpu block, all copper and lucite
    4. reseviors, any cool looking ones i can get in the states? same with pumps?
  2. Twinsen
    Twinsen What's a Dremel?
    28 Aug 2003
    No, not required...but recomended, they make like a 10c difference
    well, eather use clamps or zip ties...'cause if you don't it's way more likley the tubeing falls off...
    As long as you use distilled water and something like zurex, you shouldn't get currosion...
    Dunno...I just got a Danger Den bay res and I got a PolarFLO pump which looks pretty sweet...
  3. shroom
    shroom What's a Dremel?
    6 Aug 2003
    Master Yoda, is that you?
  4. richard-wong
    richard-wong What's a Dremel?
    6 Aug 2004
    regarding clamps, i used those thin PTE tapes. cos my cpu block is LRDW whatever its called. and the barb came with it isnt decent. so clamp it made it leak, and the death of my 9800 was due to that :( i was very angry.
    careful with clamps indeed. i would strongly recommend wrap a couple layers of those tapes to seal off any gaps.
  5. Da_Rude_Baboon
    Da_Rude_Baboon What the?
    28 Mar 2002
    emm you sure about that? That seems a rather high figure. They do help but that seems a rather excessive difference.
    Is it an Asetek kit your using? If so what type of connectors does it use as iirc they normally come with pushfits while the DD probably uses barbs. Is the Asetek kit 10mm or 1/2" as you need to ensure its compatible with the DD block.
    I think you need to do a bit more reading. :thumb:
  6. SteveyG
    SteveyG Electromodder
    23 Nov 2002
    That is a rather large difference in temperature. Where did you pluck that figure from?? :eyebrow:
  7. Nexxo
    23 Oct 2001
    Yes. Less noise, more cooling.
    Close your eyes. Clear your mind. Your mind is like a blank slate... like a peaceful lake. Not a breeze disturbs it. Not a single ripple over it's mirror-like, smooth surface. Now imagine your PC. Imagine several thousand bucks of precious hardware. Imagine tubing winding its way amongst it, carrying soothing coolant to hot and laboured silicon. Now imagine a tube becoming undone, leaking. Imagine water spilling over the inside of your precious hardware and shorting out everything in a cataclysmic storm of sparks. Now ask me that question again.
    Mix your blocks, but don't mix barb diameters. All blocks should have the same diameter barbs.
    Yes. I refer you to the sticky at the top of this forum. Check out the US site addresses. ;)
  8. Twinsen
    28 Aug 2003
    oops, I ment 10f not 10c :hehe:
    And I got the number through my own system
  9. Gajdycz
    Gajdycz Banned
    25 Nov 2004
    so how do i mount srouds? pics?
  10. scotty6435
    scotty6435 What's a Dremel?
    4 Sep 2004
    You bolt the shroud to the radiator and the fan to the shroud. Simple as that.
  11. Jumeira_Johnny
    Jumeira_Johnny 16032 - High plains drifter
    13 Nov 2004
    Eloquence that is the envy of the modding comunity.
  12. wharrad
    wharrad What's a Dremel?
    26 Jul 2003
    noticed a few people have had mixed results from shrouds, but more likely or not they'll improve things.
    Only reason I'm re-itterating (spelling?) the words of the wise is that some rads have a shroud bit already.... the fan mountings on a black ice extreme is 10mm-ish away from the rad already.
    Ach, I'd go for one if there's space anyhow
  13. Nexxo
    23 Oct 2001
    Incorrect; 3mm exactly, which is negligable. A good shroud should be at least one inch deep.
  14. Leeum
    Leeum What's a Dremel?
    16 Feb 2004
    Some radiators come with shrouds, i imagine a BIX3 does. You can always make/ buy another one for it like you do with heatercores for better performance; Nexxo made one for his BIX on his thread, check it out.
  15. scotty6435
    4 Sep 2004
    Make sure the seals between the fan/shroud and rad is good. Don't want all that lovely air pressure blowing out the sides now do we :D
  16. Haddy
    Haddy World Domination
    22 Jan 2002
    Less dead space from the fan motor so that more air passes over the center of the fins...in a nut shell...
  17. Nexxo
    23 Oct 2001
    Not per default, but if you know a shop that sells one, a linky would be appreciated... ;)
    Hey, don't get all technical on me... :p
