Cooling Water cooling
Discussion in 'Hardware' started by kynigos, 29 Jun 2010.
  1. kynigos
    kynigos What's a Dremel?
    18 Jan 2010
    This is the Rig i am planning and as a sugestion in my othere post I think it will be good to get some water cooling in the system big enugh case and i think its about time i do my first water cooling Loop :).
    6gb 1600Mhz 9-9-9-24 ram
    750w corsair Nice power suplies all i read about them is BUY BUY
    Corsair 800D PSU
    Lite on blue ray/ dvd
    2Gb xfx 5970
    intel i7 930
    GA-x58-ud3r
    120 gb ocz RevoDrive
    Price is at £1.737
    Thats the rig i got 2000 to play with and just need the water cooling now but i know nothing i am sure i will be fine putting it in I just need the componants to do it.
    It will be a great great help.
  2. Delphium
    Delphium Eyefinity enabled
    18 Mar 2007
    I would highly recommend you take a look at cooling configurator, you can create a virtual loop and it will help you detemine what parts would fit your hardware. Site run by EK, so expect only EK blocks.
    Hope that helps.
    1Thing you will want to make sure of is to try and keep all your water blocks as the same material (ie copper only) to prevent any cross metal contamination/corrsosion.
  3. kynigos
    18 Jan 2010
    Thanku for that taking a look now nice one
  4. Bitemarks666
    Bitemarks666 What's a Dremel?
    7 Mar 2010
    are you after a CPU only loop or a CPU and GPU loop?
  5. Sh0cKeR
    Sh0cKeR a=2(s-ut)/t²
    21 Aug 2009
    I'd suggest running a seperate CPU and GPU loop considering the Corsair case can't fit a huge radiator like some cases. For the CPU loop, I would strongly advise having a 360mm radiator in the top with scythe Gentle typhoon 1850rpm fans fitted. You should then add in the swiftech mcp 655 pump for maximum flow rates, and probably 1/2" ID 3/4" OD tubing. As for the CPU waterblock, you can't go wrong with either an Apogee XT or Heatkiller 3.0. You can then choose whether to have a 5.25" drive bay reservoir, EK multi option cylindrical reservoir or perhaps even a simple T-line. For the GPU loop, you can fit a 240mm radiator in the bottom area of the 800D, again with the Scythe Gentle Typhoon fans. Because of the potentially massive vibrations coming from using another MCP 655 pump, a DDC pump would definitely do the job for the small loop and would take up far less space. You can then pick up any 5970 waterblock and install it, but I would suggest looking at the EK FC5970 and Razor 5970 blocks especially. For the reservoir, you have the same choices as before. For a build like this, I would suggest buying 2 litres of coolant just to be safe, as well as using compression fittings when possible.
    I have no idea whether that helps or makes you more confused, but thats what I would do in this situation.
  6. mars-bar-man
    mars-bar-man Side bewb.
    17 Apr 2009
    What shocker said, but I would switch the 360 and the 240mm rads round, so the 5970 is being cooled by the 360mm rad. Oh, and maybe make it 3 or 4 litres of coolant, my loop, only a CPU and 120+240mm rad uses just over 1 litre.
  7. Sh0cKeR
    21 Aug 2009
    A 240mm radiator can't handle the high temperatures of a 4GHz core i7 like that of a 360mm, so I think its a better idea having the best possible cooling on the CPU. Even with a smallish radiator, the load temperatures of the 5970 are going to be in the region of 30-40c cooler than that of stock cooling, which is more than enough to overclock the card and keep it well under 60c.
