Cooling Water water everywhere
Discussion in 'Hardware' started by phenomx3, 24 Dec 2003.
  1. phenomx3
    phenomx3 What's a Dremel?
    4 Oct 2003
    What is the best waterblock for £50 or less? i was thinking of a Danger Den Maze 5 or the Asetek blocks!!
  2. M_D_K
    M_D_K Minimodder
    3 Apr 2002
    im asssuming you mean RBX :D
    [imb]http://images.lorquis.net/mdk/IMG_0362.JPG[/img]
    I'd deffo go for that one
  3. RobbieGSM
    RobbieGSM Banned
    26 Nov 2003
    he means this one (made a mistake in image name)
  4. phenomx3
    4 Oct 2003
    Yeah thats the one...damn it looks so beautiful. Asetek have dropped prices by 50% and they are tempting me!!!
    What do you do with the extra outlet? Do you link them together later on down the loop?
  5. Darv
    Darv Bling!!
    12 Aug 2002
    Well Asetek blocks arent the best performers so I wouldn't bother with them.
    And blocks with the 3 barbs are so that the water can be sprayed straight above the die. The two outlets can then be connected back together with a Y splitter, or used for something else.
  6. phenomx3
    4 Oct 2003
    thanks very much
  7. M_D_K
    M_D_K Minimodder
    3 Apr 2002
    are yes so i did damn lol
    anyway follow the 2 tubes ont he right and left of the middle tube they are the outlest leading onto a brass y splitter, thats the best way to do unles you use a manifold.
  8. phenomx3
    4 Oct 2003
    How is this for a setup:
    Danger Den Maze 5 RBX,
    Black ICE Pro 2 Radiator,
    Tygon tubing,
    Eheim 1048,
    Critcool PCI Pump Relay Card,
    Typhoon 5.25" Bay Resoivior,
    Water Wetter.
    Is this a decent water cooling solution? Can you have UV dye mixed in with water wetter?
    Merry Xmas
  9. TetarZ
    TetarZ What's a Dremel?
    16 Dec 2002
    Probably a very expensive setup but it should perform rather well. As for uv die and water wetter there shouldn't any probs. Watch out on those danger den blocks to secure the fittings (usinig colars or such). they aren't puch ins.
    Good luck
  10. phenomx3
    4 Oct 2003
    Well I have learnt a few things...if you are gonna do things...do them good.
    It was one of the most expensive setups I found :D
  11. PeA_NuTz
    PeA_NuTz What's a Dremel?
    28 Dec 2003
  12. Darv
    Darv Bling!!
    12 Aug 2002
    Most people think if they have a huge noisey pump they will get much better peformance.
    Actually a 1048 should perform fine with that setup. But you that type of block is designed for high flow. It depends whether you want a quiet pump that won't perform quite as well, o a loud pump that will peform better.
  13. phenomx3
    4 Oct 2003
    I think I may get a Danger Den Maze 4 instead. It was the block I was gonna get until I saw the RBX. It has good performance which surely is not beaten hugely by the RBX.
  14. M_D_K
    M_D_K Minimodder
    3 Apr 2002
    my setup is running an Eheim 1048 with 2 RBX blocks and its fine :D running in the 30s :p so im happy
