Cooling Water Wetter?
Discussion in 'Hardware' started by ICDragon, 18 Sep 2004.
  1. ICDragon
    ICDragon What's a Dremel?
    25 Jul 2004
    Whats the differance between Zerex Racing Super Coolant and Redline WaterWetter? are they just differant brand, or are both needed in your WC system?
  2. Darv
    Darv Bling!!
    12 Aug 2002
    You only need to use one addative. I've not used either but I've heard good things about Zerex. althogh it turns the water bright pink.
    As long as you follow the instructions with Water Wetter you shouldn't have a problem. A lot of people have problems with it becasue they put too much in.
  3. dreamreality
    dreamreality What's a Dremel?
    4 Mar 2003
    Watter wetter just helps prevent corrosion, but its not really needed now with new setups. It's suppose to help reduce temps, but i haven't noticed any temp diff once i added water wetter. it also stains your tubes white if u add too much. but its easy to clean with a little bleach.
  4. Brew
    Brew What's a Dremel?
    8 Apr 2004
    Water Wetter does pretty well but it will stain your tubes after a while, even with just a little. My res took it in the pants as well, unfortunatly I have no idea yet how to clean it :sigh: Its seems like regular antifreeze mixes do the best in most setups ive seen, I havnt tried it yet though.
    Brew
  5. Firehed
    15 Feb 2004
    What's the "right" amount? I've heard anything from a couple drops to a capful+. The only person that seems to have used it right sounded like a few drops and not enough to produce a noticible color in the water.
  6. Darv
    Darv Bling!!
    12 Aug 2002
    Yep, less is more in this case. Use too much and you will end up with a frothy mess.
    The best thing to do is read the instructions and mix it before you fill it so you can get the right ratio.
  7. f U z ! o N
    f U z ! o N What's a Dremel?
    1 Feb 2004
    ive also heard that water wetter smells HORRIBLE so if you spill some buy some odor bombs for teh house. lol
  8. dreamreality
    4 Mar 2003
    yea it smells really bad.
    i would add about 10% water wetter and 90% water.
    try adding some bleach to ur setup, it might be able to unstain ur tubes a little.
  9. Firehed
    15 Feb 2004
    lol from what I heard it should be more like 0.1%/99.9%
  10. Nexxo
    23 Oct 2001
    I have some experience with Zerex Racing. The recommended solution is 5%. It does indeed, as Darv points out, turn your water pretty pink (well, Fuchsia, if you want to be pedantic about it). On the upside, it doesn't foam, it doesn't smell, and offers better corrosion resistance than Water Wetter. It does cause a slight opaqueness of the tubing however, but when it is filled with coolant this is hardly noticeable.
  11. Lowsidex2
    Lowsidex2 Minimodder
    29 Sep 2003
    I ran water wetter in high concentration (I liked the color) and it pretty much ate the acylic res I built.... eating through the seams. What a mess.
  12. Delirious
    Delirious What's a Dremel?
    31 Aug 2004
    I use water wetter in a mixture according to the instructions on the bottle. Only thing ive noticed is it tends to discolor the hose a little. It prevents corrosion and decreases surface tension which is supposed to make the water flow better. Both additives also prevent bacteria and other stuff from growing in your system. Also water wetter has a more neutral ph compared to zerex coolant.
    I've used water wetter for about 2 yrs now in about 3 different resevoirs and havent noticed it eating away at it, of course i used the proper mixture :D
    Adding bleach is a really bad idea as it actually speeds up galvanic corrosion.
    Heres a site with some good info on water cooling additives
    http://www.overclockers.com/tips1153/
  13. ICDragon
    25 Jul 2004
    anything i can do about this? could I use UV dye, and add some cold cathodes or soemthing?
