Hello I want to try a full coverage block for my 7900GTX but before I make it I need to know if the memory and the Die are the same height and if not which is higher? I can deal with the ram getting less cooling but not the core. Or maybe I should make two blocks. Or maybe everything is the same height and I won't have problems
would you happen to know if the parts are basically the same for a 7900 GS? if they are this weekend i can get a few measurements for you
I believe so But I answered my own question by looking here It looks like the ram is about 1/16 lower than the core. This is good but I'll need to find the exact thickness. I'm thinking for the ram pads I'll just solder some 1/16 squares of aluminum to the bottom of the block
