Cooling Waterchill CPU/VGA/Chipset Cooler
Discussion in 'Hardware' started by sja360, 6 Jul 2003.
  1. sja360
    sja360 What's a Dremel?
    3 Jul 2003
    I have got a 2700 Athlon XP 333FSB and i was wondering does any one know of what temperatures roughly i should expect using the waterchill kit?
  2. olv
    olv he's so bright
    23 Sep 2002
    You cant predict temps, there is a million different factors that come into the temps you will get. Also motherboard temperature sensors can be very inaccurate so the temps you see and the actual temp could be very different.
    So really there isn't an answer to your question
  3. Jamie
    Jamie ex-Bit-Tech code junkie
    12 Mar 2001
    You will expect to get lower temps that you would with Air, I upgraded from an Alpha heatsink to the waterchill which increased my max stable overclock by 100MHz. I can't say what the temperature drop was because my motherboard sensors are all over the place.
