Watercooled PC60 for a friend.
Discussion in 'Project Logs' started by Whizzleteets, 1 Apr 2004.
  1. Morpheon
    Morpheon What's a Dremel?
    21 Aug 2003
    HA. you have my old fisher boom box!!! nice work by the way...I hope he is paying you!
    :dremel:
  2. hprcrazyguy
    hprcrazyguy Minimodder
    31 Dec 2001
    mount the pump as in pic 2 but make sure you set it far enough back to clear the hdds that may be in teh rack cause iirc they stick out the back a bit... :/
  3. kh15
    kh15 What's a Dremel?
    10 Mar 2004
    how tight are those hoses on the fittings?
    what happens if water leaks on cards etc.?
    is the pump noisey?
  4. Whizzleteets
    Whizzleteets What's a Dremel?
    11 Nov 2003
    Yeah, that's the crappy part... no matter how I mount the pump it's going to block at least one of the HD spaces in the rack. He'll probably never fill up the 120 gb drive anyway, but it'd be nice to have as many extra spaces for HDs as possible.
    The pump will be mounted on rubber grommets, so it won't make any noise at all. I've already had the w/c system together once and ran it for a bit, the pump is just about silent as is. I figure a little extra vibration protection can't hurt though.
  5. JavaDog
    JavaDog What's a Dremel?
    13 Mar 2004
    No chance on the Floppy Cage...?
  6. Whizzleteets
    11 Nov 2003
    I just don't think the pump will fit in there at all, without any modification of the 5 1/4" bays. As it is now, I can't afford to lose any more of those, since there's only one open after the bayres is mounted. I can check tonight, but I'm pretty set on mounting the pump as it is in the 2nd picture.
  7. JavaDog
    13 Mar 2004
    That's cool, your mod, I was just curious. It does look like a tight fit.
    Is it bad for the pump to mount it upside down? :naughty:
  8. th3madc0w
    th3madc0w What's a Dremel?
    7 Oct 2003
    just a sugestion, but u could mount the pump like in the second pic, but change your intake barb from straight to a 90 deg pointing up, that would make all the hd mounts usable
  9. Whizzleteets
    11 Nov 2003
    Got all the w/c stuff mounted in place, clamped, and started on the ol' 24 hour leak test. I also threw the pc parts together to make sure everything works, and about **** myself. Didn't boot up right away, so I went through the typical troubleshooting routine and took out the vid, then the ram, then finally the processor. Looked at the pins, and blam, 2 of them were bent. Between my stepdad and I, we managed to bend them back straight without breaking any, put it back in, and it booted up like nothing ever happened. Whew.
    On with the pics, again!
    Pump in it's new location, fits like a glove.
    Well, after I trimmed it down a bit, anyway... [​IMG]
    Had to route the power cord somewhere, and I noticed this nice little hole in the drive cage... but the tab underneath was blocking the cord from going through. A little dremel action later, and that's not a problem any more. [​IMG]
    All the w/c gear hooked up, starting leak testing. All the hoses have been cut to their final lengths (I think). [​IMG]
    Just a few more shots of the system during leak testing. [​IMG]
    There are still a few bubbles though, dammit. [​IMG]
    Last shot, of the pc testing phase. I <3 that monitor, woo boy. [​IMG]
    End of update, I'm going to work on it more on Thursday.
  10. JavaDog
    13 Mar 2004
    :clap: Yay!! Floppy-Cage Mounted Pump RULEZ!! :D
    Lol, seriously, glad it worked good for ya! :thumb:
  11. mopery
    mopery What's a Dremel?
    22 Feb 2004
    Its looking great
  12. Leeum
    Leeum What's a Dremel?
    16 Feb 2004
    Would that friend happen to be me... :D :D ok then it aint :idea: :waah:
  13. Whizzleteets
    11 Nov 2003
    Got all my **** in one pile, and put everything together. Now, all I'm waiting on is the right vid card, and it'll be good to go. I haven't tested out the OC potential yet, though. That will have to happen soon.
    As usual, on with the pics.
    Biggity bam, bitch... no more bubbles.
    Bare processor, with the studs for mounting the waterblock in place. I forgot to take a pic after I put AS3 on it.
    Thar it is, mounted and tightened down. Looking good so far.
    Better angle:
    Helo thar crappy old video card. You'll work nicely for testing the gpu block, I guess. Hopefully the right card gets here soon :grr:
    Vid card in place and gpu block mounted, here's what the w/c system looks like:
    Mmmm, looks good so far.
    Let's format some ****, eh?
    There she be, Win2k installed (temporarily), purring along nicely.
    Sweet PC plus sweet monitor = mmmmmmm...
    Look at that rat's nest, I'll have to see if I can clean that up a bit before I ship it out.
    Well, it's pretty much done so far, I'll post benchmarks and stuff once I get it formatted with WinXP and oc'd as far as I can push it.
  14. hprcrazyguy
    31 Dec 2001
    dude, that looks clean, love how all the tubes are just the right length and go right where they need to. and that monitor looks sweeeeeet
  15. x3r0
    x3r0 What's a Dremel?
    29 Oct 2003
    Thos 31/2" bays are begging for an lcd now :dremel: :D :hip:
  16. Atomic
    Atomic Gerwaff
    6 May 2002
    The pump fits so snugly in there and looks so neat. Good job.
    Wanna know what OC your gonna get with that setup now :D
  17. Starbuck3733T
    Starbuck3733T Look out sugar, here it comes
    16 Sep 2002
    You can get a right-angle barb for the pump input, that'll keep your cages useable. I use one on goliath and I didn't cut the flow rate down too much (enough for me to noice at least). If you can get a LARGER barb than 1/2" ID for your pump inlet and get the same as an output from your res, you'll be golden. The Eheim 1250 (as stated somewhere on procooling) does massively better when it has a full 3/4" inlet to pull water through... to the tune of (IIRC) 45 or 50 Gallons/Hour better!
  18. Whizzleteets
    11 Nov 2003
    So far, it's running a Sandra burn-in loop right now.
  19. trit187
    trit187 What's a Dremel?
    5 Apr 2004
    damn that's sexy. thanks for your reply to my questions earlier.
    what'd you have planned for the top of the case, radiator hole? i've seen some nice mesh type covers done that look pretty good.
    seems like the blowhole cut and the inevitable window should be about all you have left.
    great job! looking forward to seeing the finished project.
    so if this is what the computers you build for your friends look like. what does YOUR computer look like?
  20. Sc0rian
    Sc0rian Here comes the farmer
    23 Feb 2003
    Hey nice work man thats damn sweet.
    Where did you end up putting you hard drive. Is the pump screwed down, with vibration mounts?
    Sc0rian
