Hello again i have been thinking of watercooling my gpu for a while. I have a thermaltake tower 900 case and would like to put in 2 res inside eeach side. There is a catch though I only want to watercool the gpu and not the cpu the cpu has a kraken cooler with the nice display so i want to keep that intact. i have the following thermaltake tower 900 case 2x pump res combo which i would like to use in each side like you normally see 2x 240mm rads plenty of tubing gpu block to be purchased for 3090 I would like to make use of this kit for the asthetics and cooling the gpu I was looking for suggestions on the best was to set this up in the case and which order to have the flow especially as i am using 2 rads and 2 res pumps in 1 loop. Will there be any side affects for this. 1st time i will be going custom cooling for a gpu thank you
Order of components doesn't generally matter as far as cooling goes. The coolant will reach an equilibrium temperature through the whole loop based on the dissipation from the rads Vs heat dumped in by components. It's generally good to have a pump directly after a reservoir to aid filling, and make sure the pump never runs dry. Not really an issue using combo units. Otherwise just go for the best tube route based on ease/aesthetics. Two pumps is likely overkill, but gives you some redundancy against failure, at the expense of more potential noise. If they're hardmounted they'll transfer vibrations into the case. My pump's on a bayres and whilst quiet is still the loudest part of my setup. Also, how thick are the rads? A 3090 will be dumping a lot of heat into the loop (more than a CPU would). The Gigabyte Waterforce has a 2x120 rad, but I'm sure I've seen others with 3x120. If they're thin rads you may find yourself close to the limits of the combined heat dissipation, which will mean running the fans faster/louder trying to keep up.
thank you i have 2 of these units sorry i ment 2 x 240mm rads not 120 long story i got 1 replacment kit free so cant complain http://www.liquid.cool/p/Liquidcool-Vortex-One-Advanced-DIY-240mm-Water-Cooling-Kit_64790.html
240mm is the hotspot 2 of them should be good i wonder how is the best way to put 2 of them together in series of the loop for some reason i want to get a ridgewallet
I'd do the loop in this order rad>res/pump>gpu>rad>res/pump. Its a shame you can't adjust the speed of those pumps. Beyond that it won't matter. Those pumps aren't great, but two of them will move the fluid through the system fast enough to not matter about order tbh.
thanks the pumps have 4 pin connectors which can go to the motherboard so i can control them from there i think. is this the best way to setup the loop the 2 round things are the flow meters i will make sure the pump are rotated 90 degres so the outlets are facing backwards. Can i invert the top rad upside down to minimize tubing length or is it best to have the ports at the top of the rad thanks for the help everyone i am excited to get this setup. i have ordered the gpu block so should be heere early next week
