Case Mod - In Progress Watercooling By rjkoneill
Discussion in 'Project Logs' started by rjkoneill, 5 Jul 2009.
  1. DonT-FeaR
    DonT-FeaR I know what a fk'n Dremel is ok.:D
    23 Jul 2008
    yeah looks soo clean!
  2. maRiio
    maRiio What's a Dremel?
    27 Jul 2009
    very nice sleeving. one of the best things u can do to your rig ;)
  3. rjkoneill
    rjkoneill What's a Dremel?
    11 Feb 2008
    thanks - thats the look im going for - the colourscheme has taken me ages to finalise
    but the general attention to detail i am trying to put in takes up the bulk of the time
    every time i get a section done, i spot ten more things i want to do!!!
    i know, its addictive!
    i hated it at first and my 8 pin adapter turned out a little wonky :waah:
    however - the rest of my sleeving has turned out great, i am really happy with it
    i know it has been done to death but it does look great
    thinking of buying another batch of sleeve to do more bits and pieces :naughty:
  4. rjkoneill
    11 Feb 2008
    right then - a bit of a turnaround after my holiday
    my initial plan was to get a pair of blocks for my 285's
    these cards were not reference design so this has hindered me slightly
    in the fact that i cannot get blocks from v1 or v1 285's to fit my graphics cards [good work ASUS]
    so i had to sell my 285s [at a loss :(]
    meaning i had a choice between a single pcb 295 or crossfire 4890s
    so im going for the 4890s as i fancy a change
    will have the cards tomorrow and plan on ordering the nickel/acetal blocks from EK this week
    not ideal as i wanted koolance to match my chipset block
    but beggars cant be choosers
    plus i doubt they will be in my rig longer than 6 months anyway :D
  5. DragunovHUN
    DragunovHUN Modder
    30 Oct 2008
    Hardly possible.
  6. rjkoneill
    11 Feb 2008
    new cards are here and being tested in my current rig
    i will have to wait until some funds become available to order my blocks from EK
    i have also ordered a bunch of fittings to arrive shortly:
    1X Bitspower G1/4 Black Sparkle Rotary 45
    4X Bitspower G1/4 Black Sparkle Stop Fitting
    1X Bitspower G1/4 Black Sparkle Rotary 90
    1X Bitspower Premium Black Sparkle D-Plug Set NORMAL
    14X Bitspower G1/4 Black Sparkle Compression Fitting - 7/16" to 5/8"
  7. perplekks45
    perplekks45 LIKE AN ANIMAL!
    9 May 2004
    Nice black PCBs.
    Just to confirm: They'll be watercooled, right?
  8. rjkoneill
    11 Feb 2008
    of course
    looking at these blocks...
    nickel plated backs mean they look sweet and should match the koolance block better too
    i originally wanted the koolance 285 blocks but they didnt fit my silly asus cards which were non ref design
    so i sold the cards and got these lovely 4890s
    im running them now and i have to say - im noticing no difference in performance
  9. The boy 4rm oz
    10 Apr 2008
    Nice cards, and awesome blocks to boot, nickle plating Cheesecake.
  10. maRiio
    27 Jul 2009
    definitely the most beautiful water blocks you can find imho.
    nice choice :thumb:
  11. perplekks45
    9 May 2004
    EK is just an amazing designer for blocks. :rock:
  12. rjkoneill
    11 Feb 2008
    some EK blocks arent to my taste [i have a dislike of all clear/seethrough watercooling hardware] - but i have the fantastic Supreme on my cpu and plan on using the X58 Mosfet blocks on my board too
    however - these are easily the nicest looking i have seen so far
    its going to be expensive getting the nickel plated ones as the only stockest i can find is EK direct
    however I emailled ChilledPC [my regular WC supplier] to see if they had any of the nickel plated ones - the answer was no but they can nickel plate the blocks for me to match the pics above [significantly less than the EKs would cost due to shipping/import taxes etc]
    many thanks to Tom from ChilledPC for suggestion the idea and being so quick in his replies to me.
    also - some of my bitspower fittings arrived today [got more - these are the interesting ones]
    black sparkle nickel plating is epic, my [fail]photography does not do them justice
    i need over 20 compression fittings to match and kit out the system - currently trying to find a european supplier with the fittings i need:
    Bitspower Premium G1/4" High Flow 7/16" ID (5/8" OD) Compression Fitting
    Model: BP-BSCPF-CC6
    if anyone can help on this it would be greatly appreciated :)
  13. rjkoneill
    11 Feb 2008
    bit of work done this evening
    just odds and ends until my watercooling turns up
    still need my gpu blocks and other stuff - but european supplies of WC components seems to be dwindling
    no supply of EK blocks anywhere in the UK although i have managed to get a source for my bitspower fittings
    heres my switch pcb all braided up and reinstalled - i have a hammond box that i am in the process of cutting too
    some holes i cut in the motherboard tray for 24pin/8pin adapters and put beading round the cut edges to finish them off
    installed the rear fans and temporary guards [until my black ones come]
    heres the case as it stands
    the top half of the case sorted :)
  14. The boy 4rm oz
    10 Apr 2008
    Looking very clean, nice work.
  15. rjkoneill
    11 Feb 2008
    got one waterblock today
    not too happy as i wanted another but could only secure one
    the other is on its way from Germany to match this
    EK have impressed me with this one!
    i also got the rest of my fittings, 20X 7/16 bitspower compression fittings
  16. The boy 4rm oz
    10 Apr 2008
    I love EK blocks, they look awesome and cool very well, awesome blocks.
  17. rjkoneill
    11 Feb 2008
    finally managed to source a side panel for my TJ07
    the case i had was discounted due to it being missing, after a few emails to Silverstone in Germany - a new one arrived
    many thanks to Annika @ Silverstone for helping me out and getting the panel to me so quickly
    many have said that the TJ07 has specific panels that fit the individual case the panels ship with due to how it is made
    looks like i was in luck as mine fits perfectly
    planning a mod for the window at a later date
    also got a pack of Silverstone Aero Slots and some single slot PCI plates for my 4890's
    getting these sprayed black at the moment
    Had a power cut this morning so no gaming, thought it was a great opportunity to get in the shed and do some modding
    got a tray from an Antec 1200 at work that i thought may make a good mount for my DDC pumps
    heres a test fit to show where the pump mount will go
    i put some acoustipak on it to deaden the sound/vibrations from the pumps
    used some ehiem mounts to mount the pump, although i may mount them on top of these and use rubber grommets i got from an old striker motherboard to stabilise the pumps
    like this:
    mounted like this in my old rig
    also got a load of stuff from B&Q [hardware shop] today
    some black satin spray paint
    a set of P-clips large and small
    some cutting blades for my Dremel
    some machine screws - perfect self tapping screws for mounting fans to Thermochill Rads ;
    heres the P-clips:
    they are white plastic, wanted black ones but they will be hidden behind the mobo tray and i guess they match the fans
  18. The boy 4rm oz
    10 Apr 2008
    Nice pump mount, very clean, looks very nice.
  19. nikeunltd
    nikeunltd Epic destruction around machinary
    5 Apr 2008
    nice and clean.
  20. Top Nurse
    Top Nurse Minimodder
    31 Mar 2005
    Looks hawt! Need more pics of the sleeving. :D
